Never heard of out, Forced performance do their own hta turbo with a similar name though which I don't know of anyone using on an rb but I recon it would be a good high power combo. I know someone with a 3586hta on an rb30 and it makes over 500kw on e30 with awesome delivery.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917341
http://www.skylinesaustralia.com/forums/topic/251820-got-over-400kw-atw/page__hl__over+400kw__st__900
In this thread you will find results from 3788's, try to remember they are bolted onto big budget RB30DET's and not your average forged motor.
Considering there are 4088s and 4094s I have no doubt that garrett has simply mixed and matched some existing parts. IMHO I would expect the 3794 to be a little better under the pedal and make roughly the same power as the 4088. With the 3788 still being the pick of the bunch.
In the GTX thread I already told you to search and that if someone had one it would already be posted. Moving on..
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917415
They actually seem to push more than 4088rs in the cases I have seen, interestingly enough.
Yeah, power capability of approx the 4294 but the response of something like a T04Z
Only a turbo you would select for making easy 600hp at the wheels or pushed hard to 800hp at the wheels with the right fuel.
We use the 3788 as it's better suited to what we do/need
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-5917518
  • 9 months later...
For anyone that is interested, these seem to get less attention than the PT67 turbos but I've been a little more fascinated by these.... haven't said too much as I've been keeping an eye out for results on these things for AGES which are closer to indicating what to expect for those of us who don't want to have to rely on E85/huge boost for making good power and good spool - found that someone has run one on an XR6T and made really good power relative to boost level on one, despite being on a fairly basic setup with stock manifold etc. 400kw on 1bar on pump gas, for example... and sounds and spools awesome!
So now I'm pretty much convinced this would be a gun turbo for a big power RB that retains some form of streetability, they've made >900hp @ wheels on E85 (American dyno style, but still equates to >600kw @ wheels Dyno Dynamics if you take in account the differences) and pushed various Mitsis into the 8s.
See here:
And thread: http://www.fordxr6turbo.com/forum/topic/78068-boosted-1-in-with-446rwkw/page__p__1166770#entry1166770
Need to somehow fast track finding money to build an RB30DET suitable for such a setup :)
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6320960
  • 1 month later...
So, a 2litre EVO in the USA just put down 570awhp/425awkw on pump gas using a FP GT3794HTA (they did the 1.2 correction trick a lot of UK workshops do to estimate Dynojet/BHP type figures to get 684hp) - pretty impressive result all the same!
Mods:
· FF Shearer HTA3794 kit
· Magnus Intake w/ 65mm TB
· Buschur twin fuel pumps, ID2000 injectors
· Ported head, stock size valves and Kelford 280 cams
· 2.0 Liter Built
· Sparktech Pro CDI
· AEM EMS
Dyno plot:
Thread: http://forums.evolutionm.net/evo-dyno-tuning-results/616277-shop-fps-hta3794-combine-another-killer-pump-gas-combo.html
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6406068
So its 580rwhp with god knows what air temp, ramp rate or boost.
Cant be compared to anything....... Weigh the car..... run it down the strip.
If its 3000lbs and does 140+ then its about right.
Yeah im always suspect of DD graphs without te most important data visible. In fact we just did a test on a Mainline 4wd Dyno (new) and found quite a few variances in power outputs by changing very little 160rwkw first run r configure then run 200rwkw just by a few keystrokes...just to easy to fudge figures. Need to have the full story with dyno sheets.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407293
Fair enough, I'll keep the thread up to date with anymore info - its in the US and most people don't trust DD anyway so he is going to re-run it on a Dynojet. They sound like they expect it to do >140mph traps.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407476
^ yep, that and its running on a 2litre engine - life needs to make as easy as possible to make that kind of power.
Black bnr32, I'd love to see some dyno plots of EVOs making 420+awkw on a Dyno Dynamics dyno running straight 98 using a GT3582R.
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407528
I always used to love DD because I think they give more realistic figures compared to hubbers, but after using the dynapac lots now I'm converted. The ability to have such repeatable and consistent results so you can actually compare cars and/or modification effects is awesome
https://www.sau.com.au/forums/topic/371179-gt3794r/#findComment-6407882
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
