Hi all,
Is anyone else having loading dramas with Google Chrome?
Anytime i click on a thread or subsection it always times out!
Not just this forum, any forum.
Any ideas?
Yeah it happens to me every now and then, It's wierd because some pages will be timing out as it tries to load them, but others will load pretty much instantly, at the same time. So it doesnt seem to be dropping the internet connection or anything. And then a couple of seconds later, if you refresh the page that was timing out, it will load straight away.
I don't think its a chrome specific problem either, I remember it happening with other browsers.
https://www.sau.com.au/forums/topic/371400-google-chrome/#findComment-5920865
  • 3 weeks later...
I got a message from a torrent site (isohunt or TPB maybe?) a while back telling me not to use chrome cause it has some kind of tracking system in place and that I should please use Firefox if Im to continue torrenting ..that was when chrome first come out so I haven't used it since..Just sayin ;)
Firefox also got real buggy for a while there with problems like you are saying with chrome, so I went back to IE, but new version 4 seems to be ok and has a layout alot like chrome..
https://www.sau.com.au/forums/topic/371400-google-chrome/#findComment-5965229
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
