I've noticed that to fit my QLD personalised front plate that you have to bend the plate and make it look all crappy.
I was thinking about trying to find some rubber spacers to sit behind the bolts and hold the numberplate off the bar so it can sit straight again, but the recess is pretty deep so it'd look pretty weird like that too. I've been looking for other 33's to go up and have a look, but haven't seen too many since I noticed this... :rolleyes:
What does everyone else (with a s2 r33) do with their front number plate?
Edited by tuna_144
https://www.sau.com.au/forums/topic/371572-r33-s2-number-plate-position/
you should be able to pick up a multi-size pack from any hardware shop, mitre 10, bunnings etc. just ask for metal or tube spacers, if you can find rubber ones there I'd get those & cut them to size until you find a fitting you're happy with
take your plate screw with you to find the right size so they don't stick out too much, you won't notice the gap after awhile anyway
no way my rear plates would fit without them :thumbsup:
+1
I have the metal spacers - 2x for each screw from Bunnings & got longer screws whilst I was at it > Perfect!
I was thinking metal spacers but I thought they might vibrate or rattle - a pet hate of mine. For those with the metal ones, do they make noise at all?
I went into bunnings and asked for spacers and got the :blink: look, so I may have to try a different bunnings.
I notice now that my friend has bought a GT-T that the GTS-t's number plate recess is like 2-3 times as deep, so he only needs tiny little rubbers to make the plate fit flush.
I've also found this driver side mounting bracket on one front bar in my searching:
What's the legality of mounting a number plate there in QLD?
Thanks for all the responses btw.
Edited by tuna_144
It can be side mounted as long as it is visible from 45 degrees and 3m away from the car at each side or something like that. Might be online somewhere?
I have metal spacers and they don't make any noise. They mount to the bumper by those speed nuts or whatever they are called. But they are rubber or plastic so don't vibrate.
Ive mounted mine in drivers side of the spoiler, along the lower lip , i cut down the standard plate to a personal plate size and just drilled some self tapping screw along the bottem to hold it,
I didnt want it mounted on the front cause it looked like it was blocking the intercooler a bit, i see that bumper has the number plate part cut out to make the mouth of the spoiler bigger, ive dont that too
Edited by SliverS2
I went through my shed, found some old fuel hoses and cut them 2 size and used them as spacers with longer screws, been on car for about 2yrs now and never fell off LOL WIN
Nice ride you got there, black is by far the best colour for a skyline i reckon
Why not just drill it into the bumper? Mine looks fine. Also makes the intercooler look more visible by having the plate higher.
Do you have any pictures to show what you mean? I'm guessing you mean like what 89CAL was referring to earlier, drill holes at the bottom of the plate and lift it?
That wouldn't change the recess issue (the gap behind the plate) would it?
Mine still uses the standard number plate mounts. Phils is done with self taping screws (?) through the bumper and into the reo
Nah just into the bumper plastic, normal allen key bolts. Holds fine. One side after 5 years is getting a little bit loose so next time I have the bumper off i'll put nuts on the back of them. Will also prevent them from getting stolen.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
