Hey guys,
I've been interested in the Gtr since I heard about it and what it can do.
Im an electrician and am doing my diploma, ive just joined a class called reporting and specs.
I have till November to learn about a topic of interest and present a 3000 word written report and a 12 minute speech.
I also must have to have a target audience
Your idea can be WHAT EVER you want.
I've chosen to present a report to the Europe touring car championship, my report will include trying to organize or ask to let other cars into there tour or try to create a world tour. It's all a bit rough ATM as I've barely thought about it.
I will be basing my idea to the audience on the Gtr (as I've heard it is "faster the the 911 turbo around the Nurbergg ring")
I will also base it on alot more fun and a bigger car scene around the world (seeing as australias only real coverage is bathurst with aus cars)
Amongst other points I have in mind.
My point for this thread is that I'm sure alot of you guys know alot about the Gtr.
My first approach will be getting the manuals of the car
I'll then be looking for sources such as from the makers of how it puts that much power to the wheels
Some people may think this is lame but I think it'll interest me a little while will make me want to do it more
Hoping some people can help me with a manual download or some good websites or books.
Or info on the Europe car scene.
Any help would be great to get this ball rolling.
Jarrad.
https://www.sau.com.au/forums/topic/371918-keen-to-learn-about-the-gtr/
Don't quote Wikipedia as the source. Most claims on Wikipedia are also referenced in the Bibliography at the bottom of each page so if you use something, go straight to the source and have a look for yourself.
Wikipedia is a gold mine for academic research, as long as it's not used as the actual source.
Why don't you do a report on the R35 and the WTAC ?
A couple of threads you can get a lot of info from, including pics, graphs, video's etc. Indepth build threads right here.
Whatever doesn't make sense you can ask the people directly who are involved.
You can even post results.
Your references can be for the std cars mechanics and how altering power, aero etc changes x.y and z.
nah i don't read books to much i only have this one cause a mate gave it to me, i think the most info you will find will be in mags like "wheels" etc, anything that reports on stock cars as they are released, otherwise try the Nissan web site, they might still have a write up on its release or of the updates its had over the last few years.
Spoke to my teacher and he made a good point. It's going to be hard to find info so I guess I'll do something else :S
I thought there'd be stacks of info about it, like a whole walk through of the car and where it competes and everything.
Ohwell solar panels it is lol.
You can use wiki, theres heaps of info as it has already been said just use the wiki resources as reference at the bottom of the page.
I cant see why you couldnt find any info on it :S
i think its just a bit over my head considering its for tafe
thanks alot aaron, ive deciding im going to do a "breifing" about solar energy and try to get some new customers as i work for "joe solar" or something haha, so my main points are going to be why its worth getting, sadly ive relised theyve canned all insentive to get solar and from what ive seen its pretty pointless.
so im gunna struggle to sell it :P
would you agree? seeing as you "were" in the industry? haha
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
