I bought this car about a year ago now of the original owner who imported it in to australia. i have all the import papers with. as per normal it was ment to have all this work done to it take it to the hill climb track for it first practice and breaks valve stem guides. So one thing leads to another and we have fully rebuilt have plenty of photos of all the new parts and receipts to prove it. it is a very quick car on dont really want to sell it but i have been offered a job interstate and it isnt going to get used so would like to see someone else enjoy it. it has 12 months rego and i have only run it in an tuned and done 3 hill climbs with it. just seeing if there is some one out there who wants it. has near new kumho ku36s on it aswell. would be probably lookin for around the 23 mark which i think is quite resonable for what it is
Engine:
Rebuilt less than 2000km ago: Makes 319rwkw on 20PSI ? Tuned by RacePace
- CP forged Pistons
- ACL race bearings
- eagle rods
- OS Giken cam gears
- Oil gallery modifications
- N1 Oil Pump
- Oil filter relocation kit
- carbonetics twin plate clutch
- 1.5 way diff
Fuel System:
- Blitz 700 Injectors
- Nismo fuel pump
- Nismo fuel pressure regulator
Induction:
- Z32 airflow meters
- Garret 2860 (-5) Turbos x2
Exhaust:
- 4 inch Custom "RacePace"? exhaust - Turbo back
Cooling:
- PWR Radiator
- 28 row oil cooler
- Air Diversion panel
- Standard GTR Intercooler
Brakes:
- AP Racing 6 pot ? 360mm Rotors
- Hawk race pads
Electronics:
- Blitz Spec R Dual solenoid boost controller
- Apexi Power FC with hand controller
Interior:
- full bolt in cage
- recaro drivers seat
https://www.sau.com.au/forums/topic/372103-r32-gtr-trackstreet/
rebuild was finished in about may
rebuild was done by old man who is a mechanic of 30 years+ and tuned at race pace
it was bored out new pistons, rods, bearings clutch balanced fly wheel balanced harmonic balancer balanced new valve stem guides and seals new injectors fitted
it did but as per normal bought it of someone that wasnt really shore what had been done and first time at the hill climb track it broke a valve stem guide so did it once and did it properly now it is all good will put some photos up to prove the new pistons and all
yes still using the crank and there is no issues at all with the car. the thing with the crank is when ya smashin them on the rev limiter all the time and that is one thing i dont do can assure you of that, doesnt make you go any quicker. will get some of the in side when i have it out next. there are no back seats because of the cage recaro drivers seat no cd player not one for all the doof doof shit just nice clean and simple.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
