I was thinking about the Track Day, then I came across this:
Method for Testing Exhaust Noise:
est 1: Maintain 5000 rpm for five seconds. Requires a reading of less than 92db when measured 5m directly in line with the exhaust tail pipe.
Fail.
Fail.
I'm pretty sure a standard GTS-t will get slightly over or slightly under that :laugh:
Just do what the drifters used to do there, stuff some steel wool into your exhaust :thumbsup:
It's a king bed there isn't it? Sif not share! It's big enough you don't have to touch! :laugh:
Brett has to wine and dine me first :whistling:
Hey Andrew, if there is a spare bed. I will tale it and pay half for the room
I wasn't kidding about the floor lol the room is basically a studio with one king sized bed and no idea if there is a sofa bed. If there is a sofa bed then you can have that no worries.
Actually, I'll ring and make sure for you.
BAHAHAHA it has two chairs.....oh wait me lie, there is also a couch lol looked like a sofa. You cool with that? lol at least you wouldn't have to pay. I'm down there anyways regardless so the room has been paid for.
Edited by bored33
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
