  • Replies 58
Yes you are 100% correct - you got me on the wind chill factor mate... it is non existent for inanimate objects :/
I'll tell you what I do know about Fahrenheit though; the temps in f are different when you look at them in the context of this discussion; 180f = 82.2c , 210f = 98.9c a difference of 16.7c (30f) which I think you'll agree is quite significant.
Those temperature calculator thingys on the internet don't work that bit out for you... lol
BTW You'll love Canada; the people are great, they love to party and of course the snow is just awesome!
There are some top snowboarding spots to check out around Fernie BC (Three Sisters) where I'm originally from.
Yeh 30 degrees Fahrenheit is about -1 degree Celsius lol (as I'm sure you know being you are from Canada). So if a thermostat opens 30f below operating temperature then that is 1c below operating temperature.
It is impossible for a standard heat exchanger (radiator) to bring water below ambient temperature. That would require a thermodynamic refrigeration cycle, eg. the vapor-compression refrigeration air-conditioner in your car. Wind chill has no affect on a radiator unless the temperature of the water is above ambient temperature. If you parked a car with a cold engine out in a freezing cold wind, the water in the radiator would not drop below ambient temperature. However if you warmed the car up first and then parked it in the same wind, it would cool down to ambient temperature quicker than if there was no wind. It would never go below ambient temperature, it's impossible.
Off topic, I've always wanted to go to Canada! Intend on doing a year-long working holiday over there at some stage; snowboarding being my main activity :D
I dont think they sell them anymore i cant find it on there site.
Sorry I hadnt replied earlier.
If you are only hitting 100 deg on the track you dont need to worry so much. An oil cooler will fix that with ease, unless you have one already.
There are also antiboil mixes you can buy that will work up to 130 degrees I believe, or a water wetter agent. I would also pose the question, is a GTR rad any thicker?
Bare in mind oil is the primary cooling system, not the coolant.
Well ive got a oil cooler here and going to install this week and well see how that goes at the next drift day but since its winter and outside temps are under 20 degrees its not a problem like this weekend hit max 90 degrees so will see how it goes with the oil cooler in a few weeks.
Fair enough, I don't understand Fahrenheit in the slightest so I'll take your word on that :P
However, it still isn't going to affect much. The thermostat may start to open then but it will only be fractionally. It wouldn't be enough to stop your engine getting up to temperature. You could have a 3 meter thick radiator (for arguments sake I'm making it ridiculous :P ) and it still wouldn't stop you getting up to temp; as long as the thermostat is in working order then the radiator plays no part until the thermostat opens.
Oil cooler is the ticket.
Please document and update the post once you have it fitted, is good info to keep record of in future.
Will do, but the results will be more use for say a day where the weather is 25 degrees plus but that will have to wait til later on in the year.
Where do they them i cant find them.
Hi mate,
The HPI Evolve Radiators are a brand new product that have just arrived - They are now listed on our website for ECR33.
Click the link below for specifications:
http://www.justjap.com/store/product.php?productid=20266&cat=&page=1
Feel free to send me a pm if you have any questions :)
Cheers,
Steve
  • 2 months later...
Good son of rajab. There's so much wrong with that it actually makes my brain hurt.
Back on topic, the Justjap cooling pro ones are OK however the bungs don't always seal perfectly (get a copper washer for the water temp sensor) and if you are still using the standard airbox (rather than a pod) the JJR ones don't allow the cool air scoop to fit properly. You can still leave the scoop sitting on top but it's not ideal. The Fenix radiators are lower on the air intake side so the factory scoop still fits. Besides that no problem at all with the JJR ones.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
