56 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Right time for a pole to decide our logo design. Pretty simple, vote for the design you like the best. The logo name and number is above each photo.
I will give this two weeks to run, so the most votes at 8:00pm 11/08/2011 will be the winnah.
NismoKid 1
NismoKid 2
NismoKid 3
NismoKid 4
NismoKid 5
NismoKid 6
NismoKid 7
NismoKid 8
NismoKid 9
Autumn 1
Autumn 2
Autumn 3
Autumn 4
trust32 1
trust32 2
trust32 3
trust32 4
https://www.sau.com.au/forums/topic/372348-sau-tas-logo-poll/
  • Replies 145
Posted Images
Is this for a sticker or a logo?
Both will be one and the same. But as some raised before, we might remove the url for the logo. We will cross the url or not to url bridge for the logo when we need to use it.
You might need to use your imagination to remove the url :P
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
