56 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 145
Posted Images
quote name='zoidbergmerc' timestamp='1317280961' post='6037710']
Autumn just picked his up then, awaiting picks of him stuffing it up :P
Seriously never say anything about stuffing up/crashing on here it WILL happen glare.gif
i totally fudged the first attempt & the rest after it lol ( i will be removing the old ones at some point lol )
FAIL:
get your exacto blade out! that'll fix it right up!
The way you've done it makes it look like a shadow so it looks likes it's supposed to be like that :P haha.
You've done a stallar effort there son. The rest of you should be seeing your stickers in the post on Monday\Tuesday :)
I'm so not going to bother with the windex trick ever again, it didn't work right for me... probably too much windex.. lol
Drivers side went on easy as, passenger side was the one I tried to windex it because I wasn't sure about lining it up with the other side... cue it not drying and then not wanting to stick at all... will probably detach itself when I go for a drive today.
Anyway...
If it comes off I'll just buy another sticker at some point, hah.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
