hey all, dont know if you guys have ever had this problem, i cant hit rev limiter, i can hit 5500rpm and then the car just dies, throttle wide open, boost drops to 0 and car stops driving but still keeps revs to 5500rpm, the engine just stops pushing........no boost no pull no nothing, just stays there, with foot to the floor.
cant for the life of me figure out what it is.
but sometimes it does go away, but instead, at 5500rpm it cuts out for 2 seconds and then just keeps going as if nothing happened..
any helpful info would be great.
RB25 neo motor, no TCS in the car all stock besides exhaust and coilpacks.
https://www.sau.com.au/forums/topic/372403-problem-with-rb25-neo/
yeah i got stock ecu too wit mild mods and my ecu
freaks out when i try tap into the boost i even tryed resettin it
but when i put a nistune in it runs sick
^^ or ya spark is breakin down coilpacks plugs
but generally when that happens its more of a stutter than a
complete cut
no fuel cut though, it doesnt cut out, it just stops accelerating. boost drops, and it will just stay at 5500rpm, wont drop below that and wont go above that... bloody weird, cleaned AFM, new plugs, and new coils. checked for any leaks, nothing. reset ecu, nothing... im lost now.
if i didnt just get fired, id opt for a Power FC, but gotta save money now.
sticking wastegate maybe?????
also just found this out, it has one of 2 problems,
Problem 1: any gear it wont rev up past the 5-6k mark but if it does manage to rev normally, problem 2 occurs
Problem 2: 1st gear, revs and hits boost and its all normal, hit 2nd and it has a 1 second cutout at 5-6k rpm, change to 3rd and it will continually cut out 5-6k rpm...... and same in 4th, cant hit above 5k rpm in 5th, it can only get to 180kmh
so if its not problem 1 its problem 2...... pissing me off!!!!!! RAAAAGE QUIT!!!!
oh, bad news for me today, i decided to install a boost gauge today to see what the turbo is running, as we all know i cant read or make out what the stock boost gauge says, it says -7 all the way to +7 mmhg, so connected the new gauge which is psi, i plugged it in between the manifold and purge valve, and took the car for a run, the boost gauge hit 13psi at 5000rpm in first and hit 15.5psi in 2nd and 16psi in 3rd. so if this is anything to go by, im pretty screwed.
all i did was disconnect the boost solenoid and did the constant 7psi trick as talked about, or so i hoped. guess it seems to be a 15psi trick instead.....
just changed back to original solenoid, and it runs back at normal PSI, 350mm/hg which is 6.8psi, so the original boost gauge is pretty spot on. before it went beyond the +7 on the boost gauge (700mm/hg= 13.5psi) damn!
so the 2 pipes that go into the solenoid, i originally bypassed, hose-solenoid-hose, i bypassed that and just connected the 2 hoses directly without the solenoid in the middle. thought it would just sit at 7psi like people said it would, but it didnt did it??
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
