23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
It's about time for another stagea cruise, the weather is starting to perk up a bit and its time to get those stags out
Basic stagea cruise, Sunday morning run, down south.Great coastal run with some twisty roads in the mix.
Throw in a Bakery/Cafe lunch stop and we're set to go.
So who's keen??
Let me know when ya wanna do it and post up your interest in this thread.
I'll send out Pm's closer to the date with meeting point and Route
https://www.sau.com.au/forums/topic/372651-sa-september-stagea-cruise/
  • Replies 211
Dirty South is where its at :D
thats what i say every time some body tells me there car got stolen pinch.gif
yeah we will be in on a cruise as usual, well depending on when bubs number 2 comes out
I think you may be confused with burbs N of the fine city of Radelaide :P
I'm in. Sounds good.
You and your fascination with the dirty south though...
The fact that I live in the deep dirty south helps with my fascination.
It does suck to have some amazing driving roads 5 mins from my house tho
thats all right robbie as long as we dont look in are rear vision mirrors we wont notice the 35s :whistling:pinch.gif
any hoo 2 more 34s too add - dream 15 (ICULKN) and my little cousin will bring his stag out too :thumbsup:
Didnt realise big fella was organising 2 routes for the day . A nice long windy one for the 34S and a short straight one for the 35s all meeting together at the same time at the end so thoughtful of him, baha lol
Bringing the battery back this time to jump start the Camry? :nyaanyaa:
Lol no need this time, gonna get 10hrs of sleep instead of 10hrs hard labour beforehand, gonna need it too as the wife and bubs are coming this time
I still make us out at 1 in front too...
It's all good, someone's turbo will blow up and then you'll all be too busy discussing the idea of getting some random jap dude to tune your car for you in some faraway land.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
