23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 211
Stagea is all fueled up and cleaned ready to go!
Ditto...alarm set...see the northern folks @ 8.25amish...look'n forward to it
...might have to avoid Anzac highway is poss....them classic peeps will be all over it.
Forecast for Sunday
Fine and mostly sunny. Mild with light southeast to northeast winds and light to
moderate south to southwest afternoon coastal sea breezes.
Precis Fine. Mostly sunny.
City: Min 6 Max 19
Elizabeth: Min 4 Max 19
Mount Barker: Min 3 Max 16
Noarlunga: Min 7 Max 18
"the seriously OLD peeps"
I decided I would try to make this as I started to fit up the dump pipe friday arvo but then 2 studs snapped so the car is stuck on the hoist at a mates workshop until monday when captain thread removes them.
if you're local, caome down to the start point and meet a few peeps. we are a fairly welcoming bunchaction-smiley-069.gif
(except Big Kev... he's always angrydomokun.gif)
Lol fair enough. What happened to the rest of the M35s?
There were TWO of us... we got outnumbered by Legnums! How embarrassing...
Good cruise though, cheers Robbie :thumbsup:
BRILLIANT cruise thanks Robbie & it was a great beginning for the combined "import wagon" cruises ...was good to get to know some "Leg" owners and their rides !
Very much look forward to the next one...hope you can join us in early Dec for the Slavo Xmas Cruise
"OLD Jules & Mark'
Great cruise today guys, thanks for coming out for a Sunday drive.
Note; next cruise make sure they are more toilet and pie stops for our older stagea owners :P
Ha Ha...so that means we will be stopping every 30mins ! :whistling:
Just discovered we were lucky to make it home our left rear tyre has a (approx) 5"/12cm builders stud/nail bent in &
partly protrouding from the side wall....how "lucky" were we "old peeps"...beep changing it on the side of
the road.
OLD Mark
Thanks for the great day Robbie both the girls seemed to have a good time too. Nice to meet some new people also
Maybe you need to tow a pie cart next time though....
Hey peoples, I have started a Stagea FB page called Stageas of South Australia, feel free to post up pics and invite and of the Legnum guys, may be an easier way to share our photos. All I ask is to blank out peoples numberplates. Cheers.
And heres some pics from today.
What a sweet Sunday run!!!..Cheers Robbie! Was great roads thru all the stops! Enjoyed all the roads! Good healthy rivalry with the Legs!!!!! What happened to all the 35s only a couple holding the name! :whistling: haha
Was a good to c everyone and the Stags! :thumbsup:
"where the f*k is the bakary" haha god it made me laugh!!! :cheers:
Is the black c34 with r34 front on here? 5tagea??
At MR NISMO34 an ICULKN where there sum looks on the way home from south! " WOW r they Volvos Hahahah .. Nismo34 gets way to Many looks haha :domokun:
Got few pics to load tomorrow..seen lots of ppl taking snaps but only Aaron posting ..bring on the snaps!!!
Cheers guys!!! :thumbsup:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
