gts4 still wont be anywhere near as good build wise as a GTR, diff driveline too
yeah but youve got the base to work with.
change engine and diffs for a start to attempting to make a gtr.
could go all out and change the type of attessa.
but the maint point is OP is silly if he wants to convert a rwd 32 to a GTR.
https://www.sau.com.au/forums/topic/372683-gtst-to-gtr/#findComment-5944347
20 grand, shit you can get a clean 32 GTR for 15 these days
when you say clean you mean paint yeah?
i know this. but you better be ready to spend another 10 on maintaining the f**ker.
there is a reason a 15k GTR is 15k
https://www.sau.com.au/forums/topic/372683-gtst-to-gtr/#findComment-5944380
Thank you guys u have opened my eyes I'm just going to stick to my RWD I like going sideways more than going str8 anyway thnx again guys. Iv already ripped out the RB20 and put in a RB25 motor and box. It pushing out 211kw at the wheels. And other mods I can do to get more power out of it. I have got a Haltech ECU and I'm getting new platinum and a Slightley bigger turbo with a retune people say i will get 400hp at the wheels what are ur thoughts?
https://www.sau.com.au/forums/topic/372683-gtst-to-gtr/#findComment-5944530
as bronx said, you will need bigger injectors to get that sort of power. the stockers generally max out around 240 to 250kw, as does the AFM. that said, with those you should be able to get around 400hp, but that will be th eupper limit of what the stock internals will hold and still be somewhat reliable, so don't be suprised if it goes bang not too much longer.
to the original post, for the cost of converting a gtst to a gtr you could build a stupidly quick gtst which would shit all over a lot of gtr's
https://www.sau.com.au/forums/topic/372683-gtst-to-gtr/#findComment-5944572
Thnx bois
Yes I am also getting 750 cc injectors forgot to mention that. And I also got a after market fuel pump good for 500hp the name starts with W I forgot the name. Oh this motors only till I finish building my other motor I don't know if it should be a str8 25 or 25/30 what do u boys think?
https://www.sau.com.au/forums/topic/372683-gtst-to-gtr/#findComment-5944755
decent tyres and suspension and even an ecu with launch control will help a lot getting it off the line.
With the Haltech ECU u can program launch control. And iv already got pedders coil over right round the car grips ok for now.
https://www.sau.com.au/forums/topic/372683-gtst-to-gtr/#findComment-5944767
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
