I found this inlet manifold adaptor to fit Rb26 inlet plenum and ITB's on the Rb25's plus they do a Rb20 version
At first I thought they did the old cut and weld option onto a rb25 inlet runners, but it is different
Then I thought they had done a cut and weld onto a rb25 greddy style inlet manifold, but no
I think they have made up a new casting with mounting plates to bolt the ITB's onto and have made a remote seperate IAC box. It does away with the rb26 injector section of the inlet.
The attached pic's are are R34 Rb25det version.
Having a close look at the adpator it looks the same a greddy style manifold around the injectors ports and mounts. The flange onto the ITB's looks to be a 1 piece casting, ie not welded onto the runners.
Also the reason I think it is not a greddy style manifold is the angle of the radiator hose connection.
It is square like a factory manifold and not at a angle like the greddy.
The main negative problems with either the Blitz style adaptor plate is the angle of the injectors and the cut and shunt to stock manifold is the different runner spacing and angles.
With this version they seem to have solved those issues, I can not see any problems or disadvantage with this design
Cost is not cheap at approx $700-750 plus post form Japan etc.
Does not include the rb26 setup, so add $300-400.
Your thoughts??
I have Neo rb25det with greddy style manifold already, but would luv ITB's with VCT
Edited by darrinspencer
I found them on Yahoo. I think it will be close to $950-1000 landed
http://www.importmonster.com.au/view?url=http://page6.auctions.yahoo.co.jp/jp/auction/f101401033&thumb=http://f6.auctions.c.yimg.jp/img321.auctions.yahoo.co.jp/users/2/4/5/6/assemble2006-thumb-1297139207470101.jpg&title=RB25 NEO6 GTR KIT
As mentioned, they do a Rb20, R33 Rb25 and R34 Neo kit.
No mention on the company who makes them
They look similar quality to the other cheap chinese greddy styles manifolds.
They only cost approx $150 wholesale price in china for example.
Might try and find the supplier/manufacture as I have a few contacts and inport some parts from china now.
I currently run the greddy style copy on my Neo with gt3076r
I am very keen to try one of these out and do back to back test.
It won't be be for at least to 6-8 weeks thuo.
I can't really see any negatives with this setup?
Anyone have any idea's??
i mean when you run the rb26 ITB's it apprently eliminates the vct.
I think that would happen when you use the full Rb26 intake with injector section and an adaptor plate as it would foul the VCT solnoid>
This kit is cast the same way, ie rad hose connection as the Rb25 manifold so it will clear the VCT. win win.
I have just email Aaron at IM to see if he can contact the seller and find out more info.
i found these on yahoo yesterday also after posting my comment.
although i could only find kits for rb20 and neo rb25
my rb25 is a s2 r33 engine.
definitely do more research into where the manifold is made, im eager to purchase asap
  • 3 months later...
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
