stick it near my window Ryan......I wake up with the slightest of noises
I'd be useless at protecting it. I'm the heaviest sleeper ever, I woke up this morning to find the carpets had been cleaned while I was asleep.
  • Replies 301
Posted Images
So to recap: we have heading over from SA -
Madaz
MattR
Hostile + Mel
Dion + (2 or 3?)
Nightcrawler
Sled (nightcrawlers play-thing)LOL
Abe
Normsta
Ruby Roo
RBWARE -(Shane)
Panzer - (maybe?)
Ryan - ISC performance (maybe?)
Matty T??
Matty Sherlock
and VU!!
Anyone I have missed?
As i bought up earlier on (i think it was in here anyway), who will need extra fuel / tyres / rims / tools / etc taken over?
If we hire a small box trailer, can fit stuff in there securely and i can bring it over behind my truck :)
Massive effort from team SA! Mighty impressed...
Will be able to put entry forms up very soon, minor change of the regs once again and for a good cause...
Trying get insurance to allow passenger laps so that there can be "hot laps" in a certain R35 Time Attack car for some lucky raffle winners...
More details once they are 100% confirmed but it's looking good :thumbsup:
Under $200 for Track day & S'n'S.
Spectator entry to everything is 100% free :)
Comparatively WRX Club usually charge $190 for their members ($210 for non-mbrs) for a Winton Track day.
SAU Nats should be around $175-$185 provided the last 2 sponsors come on board. Crossing fingers in that department and should know more hopefully very soon.
Also adding more trophy classes to the Trackday, so another 5-6 or so to be announced soon.
S'n'S will be like $5 i reckon. Depends how my meeting with the council goes on Thurs (costs like security guards etc)
Burnout comp still in the air. If it goes ahead, $50 - with a $500 prize. Also have 2x 1500hp burnout comp cars that might be willing to come and give an exhibition :w00t:
Working on an after-trackday-party for the Sat night (starting say 7.30-8pm). Might be $20-$25 a head which gets fingerfood and bringing up a decent Melb DJ (or two) I know.
Merch - no idea on costs yet. But looking to do a t-shirt/DVD combo, meeting with suppliers in Fri with that actually.
So Trackday/S'n'S + merch/night out will be ~$250 I reckon.
that sounds good will you try to setup a buy all in one for a 5% discount or something to help entice people to buy the whole package
Yeah pre-order/entry when they go up will be cheaper for sure, and only PAID Club Members get that option. Public won't and different pricing will apply.
"on the day" purchase will be a bit more etc.
this is floating a shits and giggles idea Ash............do you accept non skylines for the S'n'S?
My truck is a good show pony :laugh:
I thought you were pinching a ride? :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
