i run one with my rb25det its a lt12s however i only went the microtech because i got it given to me from a close mate who smashed his car otherwise i would have gone nistune or something but i dont have a problem with it
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5950162
Im also wondering is there something about them that will hold us back?
My new car has a microtech in it already and Im somewhat CBF to replace it..
If there was a major advantage I would do it.. Anyone care to sway me?
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951039
i agree ive got one already and cbf removing it and fitting AFM's etc
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951112
I just spoke to DVS JEZ quickly by sms, the basic outcome was to leave it and be happy.
Stuff like the link etc has more features but not really necessary stuff to get a good tune out of it.
In my case its an SR with VCT, I will put a window switch into it shortly and it will do everything I need it to..
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951125
my ltx12s is great,, for what i need it to do anyways?... and ppl make claims of bad cold starts, but mine starts up and idles fine when cold..
yeah my cold starts are fine aswell when cold will idle at around 1200 until warm enough then will idle at 950 i have no problem with cold starts etc
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951179
That's probably because the STD ecu is still there controlling the idle. They aren't the greatest of ecu's pretty sure they still batch fire even thought the should be able to run sequential inj/ign with ltx12.
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951213
Same with my 200, runs fine.. No stock ecu in place.
Just lazy on power, but I cant really blame the microtech haha.
Its actually as economic as factory too.. Eh we have our answers, nothing wrong with em for a basic setup.
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951418
i dont have standard ecu at all its just microtech liek i said its a rb25det in a vl commo so im runnign full aftermarket wiring loom no afm full map sensor and my cold starts etc are perfectly fine
Well sounds like they've pulled their finger out and worked out how to drive the extremely complicated IAC valve.
Can any of you comment on the sequential injection?
https://www.sau.com.au/forums/topic/373002-micro-tech/#findComment-5951540
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
