  • Replies 183
Yeah I'll have to do a ring around tomorrow. So many decent deals on stuff at the moment, just a lack of funds and knowledge on the M35s!
or just take your car off the road for about 4 day's and send me up the VB!
bet you I still work out a lot cheaper!
Hey Craig can you still do a change over unit?
I can...but have had a rethink on it.
In other words I would prefer not to as I would want to test the exchange units in my car before sending out......this would be a bit of a PITA!...e.g If someone had a bad Solenoid in there VB and didn't tell me the next person to do an exchange would get a bad solenoid and would be pretty pissed about it. I need to think up some kind of a system where this wont happen!....at the moment I have no ideas but am willing to discuss.
I'd be looking into an Express Post box; that way you're getting back the same VB you sent; even mark the VB & solenoids before you ship if you're worried.
Just depends on turnaround time; Express Post to SA seems to be around 2-3 days; also, you can track the package. It's not hugely expensive, (VB weighs 4-5 kgs) and insurance (loss or damage) for $650 is $15.
A courier service might be quicker; less down time.
Food for thought.
I'm willing to use my company's TNT account and that is overnight but I need to pickup and deliver from an address that is manned from the hours of 8AM to 5PM....we can just add it onto the bill....would be about about $20 each way from what I charge you.
PM me for further detail if you want please....or ring me!
Express Post should be overnight Sydney to Adelaide normally?
That's a pretty good idea Dale, would think it would work out well for most people.
When I send Sway Bars; it takes 3-4 longer to get to SA than delivery to WA.
Weird...
That was weird Dale, but those sway bars were heaps heavier, and a very odd shape.
Usually when I post express it's overnight to anywhere in the network.
I think Express Post for 4-5kgs would be pretty close to the $20 for TNT.
When I post link kits; I normally do Express Post (it's cheap, and has tracking) and Auspost won't guarantee next day to WA, SA and North Queensland.
The TNT option definitely sounds like the go.:thumbsup:
looking forward to a weeks break on this now as the next 4 kits wont be hear for a week.....I recounted....thats 7 NM35's and 1 PM35 I have done.......4 since Wednesday.
On other news guy's if you want kits I am after another 2 to add to the next buy.....to keep shipping costs down.
guys.....no takers on this....will be the last buy for a while.
Is it worth doing on a stock car?
Do you mean totally stock? As in nothing changed at all?
Dale's car is still stock turbo but with exhaust and handling mods and he found a big improvement.
I can not advise against my car as it is far from stock but I am very happy with the result.
Cheers
Andy
Yeah, Definitely.
Cheers
Andy
Spot on Andy; the difference is simply a night and day improvement. I have nothing but good things to say about the shift kit.
Absolutely no downside with regard to normal light throttle driving, and when you want a solid shift; you've got it. Honestly; this is the way the car SHOULD be.
As both you & Craig have said; the difference is just compounded when you are dealing with greater than stock power levels.
Cheers, Dale.
It's been 4 days now since Craig (Jetwreck) did the work on putting the Transgo components in the VB part of the gearbox. What a difference it makes!!!!
Though, it the kit isn't much to look at for your money, it's worth every cent.
As Daleo said in his posting, the transformation is stunning. No more backing off when gear changes occurring, ie; the standard box just eases up on the
throttle when it changes gear. This was disconcerting when you are hammering it. This behaviour is a thing of the past now.
During normal driving, the changes are not noticeable but when you accelerate and particularly between 3000-4000 rpm, the changes seem almost silky smooth.
Thanks again to Craig for the work. :worship:
I'd recommend this to anyone with a NM35/PM35.
Found this while I was shopping tonight, funnily enough after Craig and I had a conversation on people overcharging for parts: http://www.conceptzperformance.com/Cart/description.php?II=1198&Car_Type=G35&UID=20110915052013118.210.201.250
It MUST be better :nyaanyaa:
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
