ok i asked the guys to do all they can while the panels are off to prevent future rust. Now the guy told me about snake oil to spray inside the car frame, columns rails etc, through any little hole openings they can find i mean thats the only way to get inside there . Now guys or people with experince, do you think this is the best product for this ? or should i reccomend another product to the guys at the work shop?
I've never heard of snake oil so I cant speak for or against it. At work we use stuff called LPS3. In my experience it works really well. You can get it in aerosol cans or in a tin to put in spray bottles. The only problem is that i worknin aviation and it is approved to be used on aircraft which automatically makes it expensive. But it does work well. Here is the website anyway if pure keen http://www.lpslabs.com/product_pg/corrosion_pg/LPS3.html
ive used deodorised fish oil to rust proof car doors etc . . . .removed door trim and cleaned out gunk at the bottom of the door with a high pressure cleaner, allow to dry, block door drains with blue tack and sprayed the inside of the door from top to bottom keeping away from the locking mechanism and window regulators, when its dry reassemble and unplug drains and your done
Have you considered electronic rust prevention ?
When i typed snake oil that came up but i dont understand it, and is it even for cars? What did you understand from this electronic rust prevention.
For now im just going to go nuts with a fish oil spray can in every hole and cranny i can see ? What do you think?
You are thinking of the module fitted to a car that pulls the voltage current out of the coolant in the block so it cant rust as easily.
I sell a lot of stuff for all types of rust prevention at my dealership. There is upper body and under body, it comes in a tin can that is 1 liter.
module fitted to a car = yes ,, pulling voltage current out of the coolant = no.gif never heard of that before.
How ERP works <-- CLICK THAT
I had one fitted to my daily a few years ago, cost $200 ish from memory. got it from tint a car
tintacar link
its pretty small, i have a little unit about the size of a business card under my bonnet, and thats all you see.
I can take some pics if you like.
tintacar link
Are you saying this protects the whole body of the car? Does it break down rust aswell?
Im not saying that,,, the people who make and sell it are though, yeah definitely.
This is taken from the FAQ page of the how ERP works link above.
Q. Is it worth fitting an ERPS system if my vehicle already has rust?
A: Yes the principal of operation works the same for both old and new vehicles. It works to slow the rate at which the steel reacts with environmental elements which cause rust. Hence, whether your vehicle is new or already has some rust, the ERPS system will work to slow the rust reaction and extend the life of the vehicle. With older vehicles it is recommended that the ERPS system be installed some four to six weeks before any rust repairs are undertaken. This allows the system to react with or neutralise any rust currently in the vehicle.
Do a bit of googleing and you will find opinions for and against, some people will say its a load of crap ,, others will swear by it. I figured, its only a couple o hundred bucks spent trying to protect a $25000 car, its worth a shot.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
