So I finished my engine swap about a month ago (25 neo in a 32) and sent it off to boostworx to get a few minor things fixed up new metal intake, getting some broken studs and stuff I cbfd doing myself fixed.
Now everything was finished up last week and the car seemed great the first 5 minutes then I noticed that on 18psi when the turbo spools up whether you flatten it from 2k or rev it out slowly and then plant it at 5k it makes this flapping trumpet noise as it spools to full boost, the noise goes away after full boost has been achieved though. So if you drive it flat from 2k it happens around 3-4k then goes away, or if you rev it to say 5k and plant it it happens around 5.5-6k then goes away.
I thought possibly at peak torque the engine was cocking over and slightly causing a gasket or intercooler pipe to leak however we have pressure tested the entire system and have not found the leak, it also doesn't really happen on the dyno only on the road so we can't find it when sticking our heads in the engine bay.
The noise is an extremely loud trumpet flappy noise, being as it only happens on the road it is proving very difficult to diagnose. Apart from pulling the intake manifold off and redoing the intake gasket (I had to swap it during my coversion) I'm not sure where else to look, rather not do this as its a huge pain in the ass and might not be the issue.
Aside from replacing the clamps on the silicon intercooler joiners what other gaskets etc should I be looking at? We have already had the AAC gasket replaced and replaced the studs for the TB as they were leaking as well. Sounds like it is coming from the bottom right of the car when driving, but that could just be because of where the driver window is. AFRs are fine and the car doesn't run rich so there is a possibility it isn't a leak and something entirely different.
Any ideas be much appreciated.
Edited by Rolls
from memory this could be the stock intake pipe sucking shut
do you have the std item still
Nope just had it replaced with a metal item, car doesn't loose any power either when it happens, drives fine just the noise sounds horrible.
Edited by Rolls
Do you use a MAP sensor or AFM? If AFM, odds are it'd be running rich if thats the case. Exhaust leaks in my experience tend to be way noisier, and leaks on the manifold side tend to be harsher (almost a mechanical scream) - on the dump pipe side tend to be a bit more of a weird noise which could be described as trumpety.
These are just observations based on my point of view when I've seen these things, could be wrong - but exhaust leaks are usually pretty easy to spot as there will be discolouration from where the gas has been escaping.
Highflowed rb20 turbo, it isn't compressor surge as I know what that sounds like and it is nothing like this, I have also run this turbo on an rb25 before without issues.
Stock recirc bov, eboost street.
had the same problem, intercooler pipe hose joiner wasn't tightened properly at the IC exit
it looked fine but opens up slightly when its pressurised (on boost)
readjusted the angle and tightened the clamp, and the noise never came back again
Have had this myself.. Its the gasket between the turbo and manifold. You either reused a warped gasket or its not on tight.
Hand in hand with no notable power loss.
I completely forgot I snapped a stud when putting it on, almost certainly that, I'll give them a buzz tomorrow.
bolts between the manifold to the turbo are lose or gasket is gone :)
Getting him to have a look and replace the stud/gasket first as the inlet manifold is a flamin mongrel to do and $$
I could do it but itd be a day Id take off work without pay, might as well just get him to do it. Oh wells such is cars $$$$$
geez Rolls rookie mistake , only reason I didnt mention it was cause I thought you would of thought of it already.
Mine did it too somehow turbo bolts had just rattled loose...
Just completely forgot about it, I'm not 100% it has snapped it just seemed to free spin a bit when i had finished tightening it so I just left it in case it had snapped, that was like 2 months ago though so completely slipped my mind.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
