Is it only in 1st? K&N pods are oiled, and have had bad experiences of the oil on them getting on the afm hotwire, a spray with a bit of electrical contact cleaner helps that out. Other things are make sure it's not overboosting and hitting boost cut (could be a line disconnected/not plumbed right), or other things I'd check are change spark plugs, if they're new, could be coilpacks giving out under load.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5957967
I'm gonna throw boost cut into the mix, have you
Got a gauge fitted?
Mine has a similar issue, had it when it was stock and still does it mow, just not as bad, with every breathing mod I've done it has gotten better.
I'm running standard boost control, full 3" turbo back system with a blitz pod, and my car makes 0.9 bar of boost, ie 12-13 psi. Maybe yours is like mine and it is over boosting.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5958303
If its airflow cut you'll know when you hit it. It's a complete engine cut, feels like the throttle got slammed closed and the engine revs down. By the way S1's don't have a boost cut, no way for the ecu to know the boost pressure.
Has it always felt this way? Or just recently? The stock setups on all rb's is fairly restrictive especially the exhaust, and the stock mapping doesn't favor consistent pull through the rev range, they tend to flatten out around 4500rpm.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5958391
hey guys thanks for replying. its not sparks as i have new lithium ones. i dont hink its air flow coz my revs stay high all the way till it changes gear and keeps driving normal. its not just in fisrt gear. i first noticed it couple months after i got it which is when i put my k&n on. so maybe it is my afm?
sorry i said my car is stock but i didnt think about but i have a 3" all the way and a hi-flow cat. I got the cat put on coz i thought that was the problem. then i got my dump pipe changed and that didnt fix it either. it already came with massive exhaust when i bought it.
so its either the FM or coilpacks?
ive researched abit n thought maybe the ecu needs tuning. i dont know how it works. this is my second car but my first turbo. man the stagea is awwesome.
thanks for your help guys. please keep helping. some mechanics dont even know what a stagea is.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5960043
Overboosting is usually caused by a dodgy boost controller, or when you have the stock set up could be vacuum lines not set up correctly.
I'd say it's either your coilpacks or AFM though. Easiest/cheapest option would be try to give the AFM a good clean with contact cleaner first.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5960169
Somewhere there is a thread on checking the soldered joints insde the AFM connector. I did not do that as I had a spare.
If cleaning the sensor wire does not fix it, see if you can find the fix it thread.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5961246
Hey Guys thanks your support and help. Got my stagea from mechanics yesterday and it's running smooth. I didn't know they go so hard. Turns out the choking problem was related to my spark plugs. I didn't install them properly.I just put them in and didn't do the whole right measurement thing. Don't kno what it's called. Thanks guys. I'm happy with my car now. Also got a boost gauge so I can keep a eye on turbo. also had manifold replaced coz I had a tink crack.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5970844
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
