Hey guys,
So on my way to work this morning got stopped by the po po..
and yup they slapped me with a yellow lickey!
All they want me to do is go over the pits to get permits but have nothing wrong with the car!
i got pinged for my tyre gaps being too close low to the guards (dont even have coilovers)?? didnt know there was a law for it,
just thought there was a ride height law and the tyres clear my guards never rubs??
And also Blow off valve are they legal or not?
https://www.sau.com.au/forums/topic/373532-help-yellow-stickered/
  • Replies 43
even stock turbo cars have a blow off valve. so they are not illegal to have on your car.
is it an aftermarket one?
i'm pretty sure even an aftermarket blow off valve would be legal as long as it is all plumbed back into the system and not venting into the atmosphere.
i didnt think there was a law about how close your tyres are to your guards either. i though you had to have a minimum level of clearance on the bottom of your car (100mm) in NSW i think.
it might have different springs on standard shock which would lower the height? not 1005 sure on ride height laws..its probably different in every state..might have to confirm with someone from WA
Is yours a white or black R34 coupe by any chance? I often spot both a black and a white R34 coupe around the Bayswater area going to work in the morning.
This is also where I 'almost' got done.
fix/hide anything you think your going to get picked on for then go over pits and hopefully things will be ok. cops make up there own rules to get you to got over.
as for the height, i heard that it has to be 120mm from the lowest point so it will be 100mm with full car and tank
dont mean to be picky BUT Stock cars dont have BOVs . . .they are called recirculation valves
This is why you guys need to educate yourselves and exercise your rights.
Gap too small between tyre and guard? I'd ask to be shown that law on the spot. I'd make the police officer get whatever book he can pull out to show me the law that I'd be breaking. Stand up for yourselves out there guys!
Don't just "turn the cheek" because you turn too many cheeks and you'll have no face left.
This is spot on and the reason i have never been given a yellow sticker even though having them look under my bonnet many many times....
Had the car over 4 years with stereo, FMIC, POD, low ride, zorst, EBC in sight all the usual mods you see and they try to find anything and i make them explain.... one cop even tried to get more for not having an accessable spare tyre until i proved him that it come straight out even with the subs in the boot un-moved....
know the law and question the police as they need to be able to back themselves.... and best of all record the whole conversation on your phone for evidence :) works a treat when you go show their supervisor that they are tools and have to appologise to you :)
FYI: they record you so you can do the same
Yeh not true. My mate got in a lot of trouble for recording a conversation with a police officer. What's more, when he took them to court, his recorded evidence was dismissed as it was 'not acquired lawfully'.
one rule for the coppers and one rule for everyone else. . .correct me if im wrong BUT chrysler 300Cs dont have a spare tyre? just a can of FIX A FLAT?
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
