make your own. Thats what I did.
pulled the outer metal section of the shifter off (its seperated from the centre part by rubber) and cut the thread from the outer section and welded it onto the inner section. Solid short shifter, Cost = $0
Replaced bush that sits on the bottom as well. Next to no slop now and feels alot nicer.
If you have access to some tools + a welder then its a cheap option if you really want to do it. I had a spare one lying around so I just thought I'd give it a go.
I have a short shifter on my R33. From what I recall it doesn't even have circlips... It is just the shifter and a series of bushes then a clamp to hold it all in place. The shift and gear control was awesome. The sound of a solid shifter shit me up the wall. The whirring noise that the shifter throws up is terrible. The Nismo shifters have a shorter throw than stock and do not let this noise through. Any solid shifter is going to let noise through, both skylines Ive had(R33's) used the same shifter and had the same noise. No matter how much rubber shit I put around it. Ive tried a plastic, stock and metal gear knob. Metal was the worst the stock one helps get rid of it and the other drift one didn't really do anything.
http://www.ebay.com.au/itm/Nissan-Skyline-Short-Shifter-Kit-R32-R33-/320741118270?pt=AU_Car_Parts_Accessories&hash=item4aada9113e
Mine looks like this. Pretty much exactly the same. Only reason I don't use it anymore is because my current stock shifter feels fine enough and not worth the extra noise you get from these shifters. BELIEVE ME you WILL notice it. Unless you're deaf or have your music always on, its audible. My car isn't quiet either.
Ive got 3 layers. One from my old car, the current and one wrapped around the base. Still was shit lol. Its the vibration and noise which travels through the stick which is shit. They should be dampened inside but that would defeat the point of a solid shifter...
Hmmm I've never really noticed any extra noise. Its not rediculous anyway. If I had to say anything I'd say its a bit noisey under low revs high load (say in 4th gear at 30kmh) but other then that I dont find it to bad.
I got a brand new boot to go directly on the gearbox (as these always seem to be stuffed) and then ditched the lower portion of the rubber boot that sits in your car because my shifter was hitting it, I'm pretty sure I have an SR20 manual shifter but I'm not sure if its just that slight bit different or if somewhere during my modification I've bent it slightly. But anyway I'm happy with how it turned out :)
thats the one Ive bought for the R32-rb26, using VL turbo gearbox.
might try to install it tomorrow - havent worked on the car for a month so probably time to give installation a go
I actually had my short shifter taken out all those years ago.
You tend to out shift the box too often due to the short through, which resulted in crunching the gearbox quite often.
Went back to stock and much less chance to out shift the synchros etc. Just something to think about.
I dont have a lot of mechanical sympathy :D
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
