yeah the ruzic thing is very good. the only one thing I'd point out is that it's still using factory sensors which by this point are certainly past their best. all the other options like stack, defi etc come with new sensors. it does mean the ruzic option is easier to install though.
mmmm stack... wish my budget stretched that far (and wish they made a 60mm gauge)... stack gauges - http://www.stackltd....ro_control.html
unfortunately my budget only went as far as prosport gauges - http://prosportgauge...ak_warning.aspx ... does the job, no problems, good + cheap gauge with warning and memory recall.. the start up "opening ceremony" is a bit american/boy racer for my tastes though
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5963573
I've got a racepak, and it's awesome. The ability to have different screens, and be able to put whatever you want on there, is a good feature, and you still see engine warnings no matter what you're looking at
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5963806
Precisely where my obsession with them came from!
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5963885
I bought the Apexi gauges like this, they are great gauges, they dont look auto salon spec and the have a warning light which you can set to what ever you want. Plus there pretty cheap compared to the din or the other options.
http://www.ebay.com....=item588d444457
I mounted the oil temp and pressure on the little shelf above the a/c unit, and the water temp over the factory one.
IMO its prob the best way in having a stockish looking interior.
I wouldnt bother with the Defi din as they have no warning light, and the factory position is to low, on the track you want a warning light to stand out and be in pretty good view.
Edited by eightsixboy
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5964684
Yea Noel is correct. Also with my unit you have the choice of using the factory sensors or new aftermarket ones, it doesn't really matter to me. It's just an input voltage matched to a calibration table at the end of the day and you can make and load new cal tables into my units easily.
I have a new unit in the make at the moment, I'm integrating all the best stuff from my previous projects into one new one. I am hoping to have some sneak previews available soon. Working on it flat out :)
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5967403
Can you hit me up with some details? Price, spec, pics (I'm visual) and realistic time frame to commercially available? By all means PM. Cheers.
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5967876
All good questions. Unfortunately I don't have firm answers. If you have a couple of months then give me a chance to get done. Something to keep in mind with these sorts of units is the flexibility of sensors. My units support any sensor as long as you have a calibration table of voltage versus sensor reading its easy. I have put sensors through calibration for guys as well when there was no data available. I can either sniff the factory sensors or add additional aftermarket sensors. The number of channels is another thing, I am aiming for over 20 analog channels, plus wheel speeds, gearbox speed, RPM etc, GPS for lap times, splits predictive times. I will also do a sensor module with 3 axis accelerometers (gtr just sniff factory ones) and gyro to keep the cost of this one reasonable (I find the commercial ones usually way overpriced). Plus am looking at doing the 2 channel steering angle interface for the Skyline.
Data logging capacity will be in the Gigs, depending on how big a compact flash you want to put in it. I use special compact flash units that are resistant to the bit inversion you find on the cheaper units when the power is suddenly cut which can corrupt data.
Data logging rates are another thing I am aiming at getting high enough to be good for suspension travel logging, you need at least 250Hz on 4 channels to get good data on these channels. A lot of specs will say something like 1000Hz logging, but you have to divide this by all the channels and the per channel rates drop pretty quickly.
Data resolution will be 12 bits for this unit, previously I was using 10 bits (1024 steps) which is heaps, but 12 Bits (4096) will mean fine resolution for sensors even if they only use part of the available voltage range.
The system will have 3 processors, a 1.6GHz logging and graphics processor and 2 x 40MIPS hard real time processors for data capture, control lines and alarm outputs. My usual external audio alarm and dual stage shift light plus warning light that I use on the EM PRO II will be available on this unit. Including external alarm acknowledge and page select buttons.
The screen will be very cool. Gauges, dash layouts, data analysis and special modes such as Time Attack, Drag Racing or Hill Climb to configure the feel of the system for that event.
At this stage I don't want to go into the full details of the unit or the display (7" touch screen :) ) as we are still shaking down the look and feel of the interface and designing the data analysis modes. I would like to think you will be able to do post race analysis in the car and then go to the laptop software for really detailed analysis.
I have been working with a few workshops who are heavily involved with racing in developing and designing the unit. I am building the interfaces and software such that I will be able to continually improve the unit and release updates as the system is enhanced.
My plan is to get the unit to beta phase and get a group of guys to test the units in cars so we can shake down the software. Then release the unit. I am hoping the user community will provide good feedback such that I can continue to develop new functionality and data analysis screens making the unit more and more powerful.
So yea, that's where I'm headed :)
https://www.sau.com.au/forums/topic/373691-gauges/page/2/#findComment-5970011
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
