Alright cool, I was planning on doing it that way but wasn't sure if it'd be the correct reading as I tried to test the VCT with the hand controller but when I unplugged the plug for the VCT, hand controller still told me it was activating and deactivating haha
Would using a multimeter be a more accurate measure?
  • Replies 55
I'm pretty sure my car has been a manual all along though. Dash cluster is a manual one, the stock ECU that came out was a manual one and there was only one other owner of the car before me. Weird.
.....don't forget the half a dozen owners in japan before that guy too...
Ahhh I see. No dramas then, on my lunch break I'm gonna go sit in my car and start mashing the throttle without starting it haha
On one hand, I kinda hope the TPS is the problem as I'm starting to get over the fact my car barely makes more power than a midly-fettled GTS-t pinch.gif
Just a bit of an update.
Car overheated today as the rubber hose connecting the turbo water line to the block split and caused coolant to spray everywhere. Car had to get towed.
Which raises the question, if there was an issue with the cooling system, how much would this affect timing and if it does, what hardware will it affect to cause the timing issue (eg. the turbo becomes heatsoaked and in turn superheats the air)
Also worth noting the car has run hotter than normal since the timing issue surfaced, so not sure if timng issue and overheating issues are 2 isolated problems or are connected somehow.
Ideas and thoughts would be great :)
  • 5 months later...
Oh forgot to mention, knock usually occurs in the upper RPM range. At first we thought it was a VCT issue as that's when the knock starts becoming very unstable but we've ruled out the VCT by running it both plugged and unplugged.
Also worth mentioning that the fuel rail around cylinder 4,5 anıd 6 has gone from the factory greeny-metallic colour to a heated titanium sort or bluey-rainbow colour.
if the car is getting hot, and is underpowered, then there is a very good chance that your timing is retarded.
Your CAS might be stuffed.
I'd be checking the timing with a timing light, and then if you do adjust the cas, I wouldn't be driving it around hard until a retune is done.
Ok thie relates to my last post ... Tried to copy info and add using the phone ... Didnt work ...
Anyhow, just thought, if there was no change between having vct connecyed or not, could that not indicate that the vct is not working?
Also, excess fuel flow is iften used the keep the fuel rail cool. The fuel rail gettinh hot to tye point if discolouraton my indicated that you hage reduced flow out of the rail and hence cooling flow to the rear injectors or you have something making it hot. This would heat the fuel and change the fuel flow out of them. If up, the ecu would lean out the others if flow goes down, well theres your knock.
Just my thoughts.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
