Posting this on behalf of a mate
his r33 has the following problems
when its cold its hard to get the car in 2nd gear (once warmed up no problems) - been told gearbox oil change should fix this
also 3rd sometimes crunches
and 3rd and 4th gear can be rattly unless you are holding on the gear knob
was told by a mechanic that the synchros are worn on 3rd and 4th
but said he doesnt do gearbox fixing
would it be a big job to replace both synchros
and also was told if he used redline shock proof gearbox oil this may temporarily solve the issue
would this be true?
guess it wouldnt be much of a loss as the gearbox seems to need an oil change (though ive this oil is pricey)
thanks
https://www.sau.com.au/forums/topic/373829-r33-gtst-gearbox-issues/
Shockproof is not very good for your box but if you must, use the lightweight version. It will not improve cold action. Better to use Redline MT 90
http://www.redlineoil.com/product.aspx?pid=46&pcid=7
Shockproof might help, but only bandaid style help. The symptoms sound fairly severe, so shockproof might only cost him $$ with no return. Each way bet really.
Spend the money on the box and not a band aid solution, I have similar issues and the oil didn't help at all...
