I put my car on the dyno at Rotomotion on Friday to get my tune checked. I was/am using an innovate wideband that is about 3 months old. Anyway there was a 5 point difference between my wideband and the one at the dyno. Mine read 12.0 to 1 at wot. The dyno read 12.5 at wot. I got my tune adjusted accordingly. Scored and extra 5 rwhp as well. Anyway just putting it out there. It would suck to melt something cos of trusting a $260 sensor/gauge.
https://www.sau.com.au/forums/topic/373886-wideband-discrepency/
I have tuned most of it myself over the last few months. I was still at work while the car was being tuned. I didn't get to see any logging when I picked it up so I'm pretty sure they just had a look at it and changed the bits I asked them to. I got it to 247 rwhp with the stock turbo at 12 psi and they found the extra 5 rwhp by adding 1 degree to load 16.
leaning out the tune under high load/boost wont really improve fuel economy. You want to have the AFR's there Safe rather then economical
The economy comes from your lean cruise points, so at constant 60km/h, 80km/h, 100km/h etc. Having your own wideband + tuning software makes this easy and you can get it running pretty good
My best friend used to tune my car for me and he said my car actually responded better to having a bit more fuel chucked in when boosting
[quote name='89CAL' timestamp='1313234034' post='5964918'
Flame takes up more space in the exhaust, more fuel equals more flame equals more spool, that's how antilag works. If you boost up on your cold start map you will see this very well.
When I said lean it out I only meant from the 11.5 it reads now to 12. Safe is good tho. On the subject of spooling up early its gotta be lean to get the exhaust gas hot and expanded to create more volume of gas to turn the exhaust wheel. Having the timing right for spool up is equally as important. Enough but not too much or it will run rich. Cars will have more power leaner but run a lot hotter. Then you reach a point where you lose power cos there aint enough fuel there. However that point is far beyond safe under high load. Don't go there! Running lean (16.5-1)and high timing (30-39) at light load on my car is optimal as I use bugger all fuel and have the engine ready to spool early. As soon as it spools and gets up in the revs (over about 4k) you gotta cool it off with the extra fuel. Antilag is not like spooling up in the normal rev range. You use stacks more fuel and completely different timing to achieve it. Phew... back to movies and beer :thumbsup:
You don't necessarily gain more power by running it right on the edge (12:1 or so). It was discuss not long ago that the japs run 10:1 AFR's and more timing to get just as much or more power as tuning done over here with leaner mixtures and less timing.
I think 16.5:1 is a bit lean for the lean cruise AFR's personally. But that's more up to you
If the tuner is used to using a sensor in the tail pipe he should be able to do a good job but both tuners i use will put another bung in the down pipe for their sensor if there is not a spare already, Just takes a few minutes and then its there for next time.
I have thought of running super rich and more timing but haven't tried it yet. Its a pity the weather is wet or I'd have a go today. I have found though that the amount of fuel used between 12 to 1 and 11 to 1 is very noticable. I can get around 650 ks a tank running at lean at light load and obviously heaps less on boost. I have found that anything past 16.5 to 1 the car surges, although most of the time in normal driving it is under that. 16.5 is just when my foot is still on the throttle at 60kph.
12.5 is safe on a RB... when tuned right... even seen 13's on a 500hp endurance engine so 12's is nowhere near the edge.
To the OP 0.5 is often the approx difference from dump to tailpipe depending on cat and dyno pickup design at the tip.
So Trent, do you reckon that 12.5 is fine for mine? Most of the RB dyno sheets I have seen are at 12 to 1. I figure that seeing as it is only driven on the street and isn't at wot for very long it wont get too hot. I haven't got a pyrometer so I cant really tell tho. In saying that I still have a stock turbo so I dont want to spit the exhaust wheel out just yet.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
