Try and hear me out here ok :)
We used a Suzuki Ignis Sport for a recce a couple of times at Targa Tasmania.
Recce basically involves a week of driving and course checking prior to racing. They're a great little car! Handle well, and it you row the gearbox, lots, repeat, Lots of fun.
Not the most refined, but loves copping an absolute hiding!
They have Recaro seats which are really comfy, and are so crazy cheap to run.
I'd recommend one in a heartbeat.
To give you an idea on the Jazz, leaving Wollongong, up Mt Ousley, Across Picton, down the Hume to Canberra, and return, takes one take of fuel and averages 6.3L per 100KM ringing its little tit off at around 110KM/H the whole way (Not letting it cruise up the hills and lose speed... Giving it the shuffle back and getting up it)
It takes me around 35 - 38 Litres for that trip.
Around town (I live in Wollongong CBD, so often drive on the cold fuel map for most of my trips) I see 7 - 7.5L per 100KM, and that's having a fair bit of fun in it (Revving out to 5500RPM each gear basically with a fair bit of throttle)
I HAVE had my old Jazz as low as 5.3L /100KM, but that was keeping it sitting on 80KM/H on the freeways etc.
When I lived in Shell Cove, I regularly saw 6.0L flat per 100KM because to and from work was all smack on 80KM/H.
If you have the occasional "domestic", the best car for dropping her off is from the cargo area of the Cube
Take note...
http://www.youtube.com/watch?v=5Tq2-yFU9_M
I've tried doing this to my wife in the 530i but there's either...
a) not quite enough torque or...
b) I can't drive as well as Duncan
Hahaha that's an awesome video!
Yeah I know, but I dont think anyone in an sv6 will be suspecting my sexuality when the pull up next to my skyline hah.
No one I know that's my age comes close to it hah, mainly they don't have a car period.
Hey the Mrs. has a toyota echo 2000. Awesome on petrol! It goes hard for what it is aswell. As for ousley i havn't driven up that. She goes up bulli pass about 3 times a week no problem and drives from wollongong to bankstown 3 times a week, no problem. I drove it for about 3 months and is the most reliable car ever. Oil changes and servicing piss easy. If you want something reliable, good on petrol, and goes hard (for what it is) def the echo. From my experience Hyundais are a sack of shit!
she picked it up for $3600 too had 110k kms.
Edited by pac34r
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
