He has an external gate venting to atmosphere... Don't you have an internal gate? Totally different ball game when it comes to exhaust flow
Good point, that does change things. I am just bringing up the issue of exhaust size when talking about a large turbo like a GT35. A turbo which is capable of 400rwkw on 98 fuel. The rough guide on this forum is 3" for 300rwkw, 3.5" for 350rwkw and 4" for 400rwkw.
Your right external gate venting to atmosphere wont require as large as an exhaust as an internally gated turbo. I think its just worth a thought when getting a custom exhaust made up. Wont cost much extra to be a size larger and might save you getting it all redone later.
  • Replies 139
I dyno tuned a 600hp na 5L v8 in my early 20's when I worked in a dyno shop. I frequently saw 500 and 600hp go through 3 inches. We tried a 4 inch exhaust on the 600hp engine and they lost about 50 hp in the midrange and made more noise. That's all.
I know that turbo cars and na cars have different requirements from their exhaust systems and I have no intention of debating this. I don't really care that much.
You are right in saying that you should go all out when you are getting work done Harey. That's the reason I got a 6boost manifold instead of an ebay job and a genuine garrett instead of an ebay job. When I get an exhaust made I will make sure its what I want.
I will be pulling the gearbox out tomorrow after work and cleaning the flywheel, pressure plate and clutch facings. Bastard better not slip after I put it back in. And I thought my gearbox removing days were over. I guess not.
Anyway I'm going to bed. Early starts are great. Up again at 4am. Thank god its Friday tomorrow.
3.5" for 350rwkw? 4" for 400kw ??? Dont agree sorry, sounds like overkill. 4" seems way too big for 400kw (4" for 500kw + sounds more realistic to me..)
Im pretty confident i can make 400kw if my engine was forged and slightly more efficient in the headwork area and retain my 3" dump. I also fairly certain plenty people are making 400kw at the wheels through a 3" dump, i think SimonR32 knows who i remember this debate coming up before!
Yeh, my mechanic makes 510rwkw with just a 4" exhaust, including wastegates plumbed in.
Yeah its a guide for plumbed in internally gated turbos.
It doesnt mean you cant make more than 399rwkw with a 3.5" exhaust or 510rwkw with a 4" exhaust, its a rough guide. So if you are aiming for over 400rwkw then you should look at a 4" exhaust if you are plumbing it back.
Yes there are people making 350rwkw on a 3" dump pipe but a lot have 3.5" catbacks.
The test is not if you can make the power but how much power you would gain from a larger exhaust, not to mention the release of back pressure and heat.
Regarding the 600hp na 5L V8, yes N/A exhausts are completely different. The turbo back exhaust looses nothing by being too big. Theoretically you want the largest exhaust you can fit. Obviously after a certain point for each power level the gains are negligible so you dont bother. But you dont loose anything from going too big.
Being an afm based ecu air temp correction is a built in feature. Mass of air is read dosnt matter how hot or cold it is the appropriate fuel will be injected
Map sensor based cars need air temp correction due to the fact that mass of air at the same pressure can change with air temp
yer thats great for fueling but and it will run through different load cells on a hot day than a cold day in the same gear. the problem is with timing, if you tune it to suit all gears on a 25 degree day then go drive on a 40 degree day, higher gears are gonna run through the same cells as lower gears on cold days. so you'll have either too much timing for a hot day or not enough for a cold day. seperate AIT timing correction is very handy but at the end of the day you only need it if you want every last bit of power.
Agreed. If the trend continued then youd need a 5" for 500kw. Yeah right. :)
You can flow plenty through a 3 inch. Real life result: a 25 can push 360kw with a 3540 .86 on 21psi and 98ron with the gate plumbed in through a cheap 3" cat back with just a cannon muffler. Full 3 inch dump and front. It also made a bar @4000rpm. Stock unopened engine. I dont think there is much more gain to be had in that...
I dont think the 3540 is too big for street, i think its a fantastic turbo, its the best solution for that kind of power; anything bigger would be a bit frustrating. The car is still going 2 years later at around 330kw every day.
..and as for 3.5" being only a little more expensive, i think not; the mandrels are MUCH more expensive than 3" because theyre harder to make and arent as common.
I kind of agree there.
you can make decent power with a 3" exhaust (lets face it, 3" is a big bloody exhaust for a 2.5L engine), but what would happen if you changed it to 3.5"?
more power on the same boost is likely, not guaranteed though, so can be expensive to find out. >_<
So when I re-do the exhaust on my car It will be Dual 3" to make sure there is no way in hell it will give me any headaches
When I had no exhaust or dump the turbo ran 17 psi on the gate which had a ten and a seven psi spring in it. Makes sense right?
My current exhaust is comprised of a 3inch dump, 3inch front pipe, stock cat and 3inch kakemoto cat back. When I got the dump made and the exhaust put back on the turbo ran at 14 psi.
I have a bleed valve and I have turned it up to 20 psi. The car goes fine. Its nice and quiet too. I know I can turn it up more too but due to other issues it will stay at low boost (under 20psi) for a while.
When I get a better cat I will close the bleed valve and see how many psi it makes then. Of course it will be more than previously.
The current exhaust setup killed 3 psi and the point of this post is is to show I will be losing less than 3 psi using a full 3 inch system.
I agree with zebra. What is peoples definition of decent power? My car goes better than decent in my opinion.
A little update. I went for a tuning drive today with the datalogit in use. Before I went I wound the bleed valve out so it would land around 25 psi. We made the area under boost a bit richer with the afr's to help it pick up a bit better. A big thanks to my beautiful wife for being my co-tuner.
As we got out of town I gave it some cautious wot runs in second to see what boost it was going to run and to check the knock. It ran about 25psi but to be honest I didn't have a clear look. I had wound the bleed valve 2 and a half turns up from 22 psi. Each turn is about 1 psi.
I ended up pulling 6 degrees out of load 17 to 19, 5 out of load 16, 3 out of 15 and 1 out of 14. I am now running 11, 10 and 8 degrees in load 16, 17 and 18. Winding out the bleed valve makes a fair bit of difference on when the turbo hits full boost.
The afrs are 12.0:1 from 4000rpm dropping to 11.2:1 at 7000rpm.
The highest knock level now is 11. I am pretty happy with that. I might be able to get another degree in there somewhere but that will be another day.
The car absolutely hauls ass now but I could still do with some more power. It pulls from 60 kph to 100kph almost instantly in 2nd gear. After 4500 rpm even on half throttle it will get up to 20 psi or more.
The stock coil packs were missing a bit at the higher boost level. I guess it is time to upgrade them. They work fine at 22 psi though so I'll probably wait a little while yet. I might even try adding a touch more dwell in there so get more of a spark happening.
The fuel reg line kept popping off at the higher boost so ended up cruising home. I had a look under the bonnet when I got back and most of the vacuum lines had moved along their fitting places. One of the cooler pipes was about to come off as well. It seems I will need either new lines everywhere or a bunch of little clamps or cable ties.
Funnily enough the clutch didn't slip today as I thought it would but I was a lot more gentle with the gear changes.
Soon it will be time for another round of upgrades. Brakes, clutch and wheel/tyres are next.
What power are u making Room?
I haven't put it on a dyno yet. I can only go off similar setups that are on here. I would say conservatively 450rwhp. I'll get it on the dyno this week if I can and let you know.
I did not say a 4" exhaust is only capable of 400rwkw, I am saying once you go over 400rwkw you should be looking at a 4" exhaust as you will most likely get gains.
I wasnt saying you were incorrect. I agree with what you are saying. Im just stating for general knowledge that a 4" system is roughly good for 1000bhp before it starts to become a restriction. In saying that, you would probaby want a larger dump and then 4" from there back where the gas has hopefully cooled enough to not occupy so much space.
In reality if you spent enough time working it out you would build an exhaust system that almost constantly steps down throughout the whole length of the system to keep gas velocity at the ideal speed. So you could make a 3.5" dump or even 4" and then just run a 3" system from there back and it could support more horsepower then just a straight 3" turbo back system.
I did post this link in another thread to show a stock engine revving hard but since it is more related to this thread I thought I would post it here.
Just so you all know the stock tacho reads 1000rpm high in this vid. There was no clutch dumping and the 1 to 2 change was gentle.
http://www.youtube.c...h?v=ZCG9jTJozuM
What turbo u have on that?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
