hi guys currently getting my motor built at moment it will be ready to get tunes soon when its back in and i was wondering cause im new to wa where is the best place to get it tuned a reputable place ?
its a r32 gtr by the way
please pm me
thanks guys
  • Replies 55
hi there, best place in town is allstars in malaga, they do a good tune and get plenty of good feed back. im getn my r33 gts done there in the next few weeks.
Big question is who built the engine ? Whenever tuning a new engine there is alot of reluctance, cause when something goes wrong, as is often the case, the tuner doesn't want to get blamed for a poorly built engine, and vice versa.
Also, what ECU have you got, turbs etc ?
Please post results in the SAUWA Member area :thumbsup:
If the bad boy works, I'll be telling every one don't u worry,
Quick parts list
Bottom end built by me with
Nissan bearing
Spool rods
CP pistons 86.5
Nitto pump
Trust sump extension
Head consists of
Tomie -
Pro cams 270x10.8
Type B springs and retainer
Bronze valve
Ferrea +1mm valves
Tomie gaskets
1.2 HG
1000cc xpurts
GT 35 .82 vband
3.5" dump
6 boost and 48mm pro gate with screamer
040 intake and 2x 044 externals all direct wired
3lt surge tank
3lt baffled catch can with rear head drain,
Think I covered everything and all issues RB related
Let's hope it all works
  • 5 weeks later...
MOTOR BUILD UPDATE, ALL BUILT AND FINISHED GOING BACK IN CAR NOW !!! maybee some things i missed out !!
sard 700 cc injectors
brand new garret 2860-5 turbos with all new gaskets
hks exhaust gasket and tomei metal intake gaskets/throttle bodies
acl race series full engine bearing kit, along with king bearings unknown what they were for !
shim head gaskit race series (metal)
N1 water pump
tomei UMEDA oil pump
tomei 260 deg cams
custom built extended sump and pickup with trap door setup in sump (MADE BY RED R RACING )
rebuilt front diff and preload reset
engine balance
machine crankshaft
ross harmonic balencer
cp forged pistons, 30thou over size from original bore
eagle conrods
gates performace timing kit
replace crankshaft oil galleries with screw in plugs
deck block
recon head ,full set of valve guides,3 angle valve cut ,set of shim tappets to cams supplied
aftermarket valve springs
custom work (drill and weld up oil galleries in head advised by red r racing)
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
ARP Mains + Head Studs
All New Hoses And Gaskets
Oil Relocation Kit + Cooler
alloy Radiator
new clutch built by (JIM BERRY RACE CLUTCHES QLD)
Nismo Airflow Meters
New O2 Sensors
trust 600x300x120mm Intercooler,
recent full rebuild on gearbox
running the nistune ecu with nismo afms
and a blitz i colour elect boost controller
will be interesting to see how much power i will make ,would anyone know an estimate on power figure ?
Thanks I bought these brand new turbs cause I blew one up originally when I had same turbs before not expecting motor to go and make a new stronger motor with more power so yeah I hope I can make some good power anyways was hoping for 600 but oh well ...
A mate with an RB28 running 26psi and e85 with big cams and a shit load of head work made 630rwhp, so with your setup on pump98, and similar boost I'd expect around 550rwhp thumbsup.gif
Make 500 easy, pending ignition and boost will indicate how far you want to go. Camshafts could be alittle bigger for some extra hp, I changed from 260's to 272's and noticed a mega difference top end. Either way, great street and all round setup.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
