IIRC, mid to high 6's....
Search for an older thead comparing the M35 to the VE SS SportsWagon...
That was a good thread :) From my perspective I think a shade over 7 seconds for stock, but that could have been the dodgy Iphone app I was using to time it. It does feel quicker than that tho.
I think most time is lost with the throttle restriction in the first 30-40km/hr. Spend $1 & cut the ECU brake wire & put it via a switch (search for posts on this). That could shave half to 1 second off.
And welcome!
Edited by Commsman
https://www.sau.com.au/forums/topic/374780-m35-vq25det/#findComment-5977851
i dunno, the g-tek timers were fairly consistent with the track timers when they did a test in fast fours or some magazine like that
the iphone has GPS and an accellerometer(spelling) so its probably reliable.
there was a BMW branded one on the istore a while back. i never tested it
https://www.sau.com.au/forums/topic/374780-m35-vq25det/#findComment-5979081
hmm link me up on the brake cut please! :)
Here you go: http://www.skylinesaustralia.com/forums/topic/266854-m35-emanage-ultimate/page__view__findpost__p__5832870
Read on for a few pages - you should install a switch so you can "reconnect" it every so often. That will stop the check engine light coming up.
https://www.sau.com.au/forums/topic/374780-m35-vq25det/#findComment-5979267
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
