My Solution For My Car Being To Low...
fcukinky
 Share
So after my car was lowered (Still over 10cm off the ground) I had trouble getting my jack under the car in the front to jack it up.
I had a look and there was only 2 options, one was to get the low profile ramps but that was going to cost around $100 the other was to get someone to cut me some planks of wood into ramps.
I did not want Planks of wood in the boot of my car so I ened up with these:
http://www.ebay.com....=item2eb6a58754
Anyways I guess this may not be the solution for everyone but for the few people that may also be looking into a solution I thought I would share.
Paul.
  • 5 months later...
How low is your car? They've fit under all mine. Where are you jacking from?
Must be doing something wrong man!
Doesn't fit under the side of my car lol. I can't fit my iPhone4 between my front bumper and the ground :P
Fits under the diff at the back but no room to jack it up, have to drive up onto chocks.
Srs.
Raised it up 20mm this morning, this is how it sits now:
Keep in mind that's without the front lip fitted, makes it about an inch lower.
Edited by Hanaldo
Really? Is that your truck-spec 34 in your sig? I joke I joke :P
Doesn't look as good but it was stupid before. Lowered it for a car show and couldn't be bothered raising it up again after. It used to scrape if I went around a corner too fast confused.gif
Oh trust me, I cop it from all sides for that.
Obviously I was being sarcastic though, I'm pretty damn impressed with that clearance.
What suspension have you got under that thing?
Haha yeh all good mate, was just joking :P
I've got the BC Racing BR series coilovers on it. The front ones were maxed out before, the rear could still go another 60-70mm lower blink.gif Am much happier with the current clearance though, can actually drive it properly.
Did the install on mine at home, front's first got them pretty low, then the rears, was a little drunk by then and they got wound ALL the way down, just to see what they looked like. Looked boss but clunked and scraped on every little bump or loose piece of gravel on the road so they did eventually come up some.
But damn it did look good.
The 33's must be a lot different to the 34's then, there is no way in hell that the rears could go all the way down on my car without a lot of modification. Now that I think about it, the rears must have a lot more than 60-70mm still to go because the upper control arm assembly was coming into contact with the inner guard and wheel with at least 70mm of thread to go.
It was on 19's at the time, I'm not sure it would go all the way down on 17's and you can't wind them collar to collar, they stop winding before the thread does, I think to get them lower than that you need to shorten stroke length from the top.
Edited by arcticlink
 Share
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
