THIS CAR HAS BEEN STOLEN
VIN NUMBER 6U9000ECR33017453
[/size]Item Summary: 1993 NISSAN SKYLINE gts-t, loads of work done
Postcode:
Odometre: 123,000 kilometres
Contact Info: 0404 219 513
Extra Information:
even if you see parts like these for sale please let me know and i will look into it
it has pretty much had every modification under the sun
custom front fenders (not pictured)
power fc (fully wired to EVERYTHING, boost, speed, everything)
xforce highmount manifold
massive high mount setup garrett 3582r ballbearing
custom oil feed and water lines (earls,speedflow,aeroquip)
tial 38mm wastegate with 1" screamer
z32 airflow meter with k&n to suit
asi 52mm radiator (massive)
dba slotted rotors
all gates silicon hoses
greddy copy plenum polished with plazmaman adapter
nismo strut brace
nismo knob
nismo dash cluster
recaro recliners
g4 coilovers ( not a jap brand but they are okay fully adj 10kg rear, 12kg front)
adj rear camber arms
hicas lockout
front adj caster arms
tripple plate clutch
custom chromoly flywheel with direct clutches ( custom tripple plate clutch for upto 350rwk)
some sort of lsd (fairly certain it isnt stock)
ducktail wing
700cc capable injectors
turbosmart type1 BOV
catch can ( now plumbed up, not pictured)
walbro intank wired properly
full 3inch exhaust with stainless twin pipes
apline ipod dock stereo
sony amp
alpine typeS front and rear speakers
greddy front mount with full wiper kit
sard fuel press reg
has heaps of guages in the cabin mounted nicely
old school 17*9 and 17*8s near new tyres
high pressure aftermarket hoses, gates hoses everything replaced
PLEASE CONTACT CRIME STOPPERS ON 1800 333 000 QUOTE LICENSE NUMBER 912LHU
OR CONTACT SGT YOUNG OF WYNNUM POLICE STATION 33088100
https://www.sau.com.au/forums/topic/374936-stolen-black-r33/
cheers guys.. yeah sort your insurance out... make sure you have a good immobiliser or they wont cover you... they wont tell you that till its stolen either
So did you have a immobiliser? as alot of skylines are getting stolen lately (as reported on http://www.facebook.com/pages/Stolen-Cars-in-the-Gold-Coast-Area/243590732330538 ) and i always wonder if they have immobilisers or not..
Hope you find it in and will keep my eyes out
thanks guys, it did not have an immobiliser on it.. it was realy only parked out the front of my house... didnt think any scum would think of taking my car... but there are some loosers in this world
eddy,
no issue with yours.
still can't believe people think it is ok to park one of these outside a house and expect it to be there in the morning. christ I see 8-10 a month for that very reason. the last one I had WAS a 33 and I ended up rebuilding the steering column thanks to someone trying to take it. that car WAS parked out side a house and had it not been for the owner leaving the lights on it would have been LONG gone. (you know who you are when you read this)
if it shows back up send it over here and I'll rework it so the only way it will move is by tilt tray.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
