Sundays? Maybe im getting Calder and Winton confused. Sundays would be great.
Cant make it anywhere tonight as im relying on leg power to get about until i drive my car down over Easter Break.
Thanks for the offer, ill take a rain check if thats ok. You say Sam =, is that Dr Drift, i need to talk to him about some work on my car after Easter
Jamezilla... are you the same James i met at the NDSOC meeting the other week? (i was the blonde fella boring Goeff to death).
Roy, Yes it was that James along we me (Andrew) and R31Nismoid (Ash) that were at the NDSOC meeting a few weeks back. :wavey:
All of us will be at MAS this weekend so you will have no problems finding us. And there will be a big cruise a couple of weeks after Easter so you can get decent fix then.
lol yeah I am... been very disorganised lately... had my mate in a car crash tuesday nite, so it sorta messed me up a bit...
ahhh jarrod... kewll... i'll be buggin ya more in the near future :P
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
