SSS automotive were advertising GTST-4 RB20DET's for around $1000- with warranty
Fark that a good price for a 20....
but mate at the end of the day its ur choice. I too a few weeks ago i was coming from same situation u r and i stayed true to the 20.I would stick with the rb20 because they arent as shit as people say they are and with a good setup and tune they can be a f**king weapon,u can boost the f**k out of em because of there lower compression and if u take care of it it will last you a long time :worship:
  • 11 months later...
  • Replies 42
Found this old thread and decided to dig it up.
Cars still off the road, But has the following:
Rb25 from s1 stagea, pulled appart, crack tested, acid dipped, bored & honed.
Weisco forged pistons .5mm o/s
Tomei poncams
Tomei valve springs
Acl race series bearings (full set)
Arp head stud kit
Cometic 1.01mm head gasket
+ new oem gasket kit ;) + porting etc.
All from www.rawbrokerage.com parts were cheaper than my engine builder could get in, very happy with their service.
Motors ready to go, now I'm sorting out my loom options, and once it's running will be coupled with ext gate gtx3076, e85 and 20-22psi. Aiming for 300-350awkw. So much for 250 awkw haha!
Build thread coming soon
Cheers for everyone's help, took me a while to wake up to the 25, the 20 can be a paperweight.
If you have a S1 stagea motor the ecu will be no good to you as it can't be Nistuned. Look for an R33 loom and then you can fit a Z32 ecu to Nistune or put a Link or Vipec in the R33 case. Trick wire to look for: the one from TPS to Atessa.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
