All
I've got a lot of performance stuff to off load as I need the money for my Diabetic 4yr old son. All of this is what I've been collecting to build up my car, but can't proceed and is either not yet fitted, or I am removing from the car.
Lots brand new, too many items to photo everything, however most of you know what these items look like, pics on request for serious buyers.
New items
power fc + HC, $950
Nismo FPR, $220
Sard 700cc Inj, $750
Z32's + adaptors, $700
Gandor Mirrors, $100
cooling panel, $200
universal FPR, $70
GTR diff bushes (set of 4), $100
Greddy rear pods painted silver (KG1), $200
Used items
Momo leather steering wheel, $200
Full Cusco hard pipes (turbo outlets to plenum), $600
Tomei Poncams like new lessthan 2000km - Boxed 260 deg 9.15 lift, $700
N1 spats painted silver (KG1), $150
Duke intake hard pipes (afm to turbo intake – has BOV and rec fittings), $130
Stock intercooler, $200
Alloy radiator radiator 52mm fits with stock shroud, $160
GTR Diff, excellent condition, polished cover and black enamel housing, $300
ATS carbon twin plate GTR clutch CN23210H less than 2000km, $1350
HKS cam gears, $200
GTR wing Silver, $100
Sparco racing rims fitted with v.good 275/40/17 KU36 semi's, $1,400
Nismo Leather Steering wheel, $100
GTR steering wheel boss, $100
I may consider parting with my HKS GT 2530’s, but as I bought these brand new and paid though the nose, won’t sell them cheap less than 2000km use. I suspect most people are better off getting the garretts if you want cheap.
happy to post - you pay freight.
please PM or contact 0413377742
Dan
https://www.sau.com.au/forums/topic/375086-performance-gtr-parts/
My GTR is R32.
Lots of requests for pics.
list what you want to see and I will get them tomorrow.
I will call those back that left a message on phone (was in a meeting). please PM rather than SMS as I don't know who is requesting what and as I have people after the same items, it will be first in first served.
I've had about 300SMS and don't know who wants what!?!?! please PM with your request othewise you may miss out.
Cheers
Dan
Edited by DAN00H
any picture for the GTR wing?
no pic of wing, but it's a stock GTR wing in silver
all my other pics are over 2mb in size, so send me your email address and I will send by email (CBF attempting to post them here)
Edited by DAN00H
Update
lots of pics finally emailed out (appologies for the delay).
Mirrors sold
Diff provisionally sold
below items not yet confirmed as sold, if interested get in quick!
Cam gears
N1 spats
Hard piping
Radiator
Garage Defend GT coolong panel
Nismo steering wheel
GTR wing
Oh - I'm at home and don't get mobile reception (just heard it ring) - please PM or SMS (with SAU ID)
Happy to take or email more pics - Momo race wheel is very nice :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
