Come to think of it, I should enter the Caldina in the upcoming 1/8 mile event. It would be quicker off the line than the 33 anyway, considerably quicker (mainly because I suck getting out of the hole in the 33).
  • Replies 76
Mind you, if someone had given me the opportunity to run the 33 over the quarter mile at any stage in the last 4-5 years, I wouldn't have cared if they gave me the details of my run on a piece of toilet paper and written in crayon... as long as it wasn't used toilet paper.
Hey Pete, yep as per my sig. Mind you, I never had a chance to run with the old 275/40/17 ET Street Radials and put my experience (at the time) into practice with a decent drag radial tyre. I did the 2.051 on the old 275/40/17 Nittos (without doing a decent burnout) which weren't anywhere near as impressive as the ETs.
The 265/40/18 isn't the ideal option for drag racing, but I like to do it the hard way... with the car looking pretty in the process (18's as opposed to 15-16's on the rear). I've also replaced almost all of the original suspension components since those old runs back in 2005-2006.
I'd estimate an 11.XX something at high 120's now.
The run against the Torrie was without doubt my best launch to date (it's the 2.051) and I even got a good solid shift into 2nd and 3rd. Unfortunately, the Torrie got out of shape at the 1000ft mark and I lifted off the throttle whilst doing some high speed decision making, 'do I nail it and go by the carnage unfolding, or do I hit the anchors and try to pull up clear of it?' I nailed it. Ended up with a mid 12 at 110MPH after completely lifting off the throttle at 1000ft. Still reckon it was the 11 I'd be chasing for 6 months. Fast forward 5 years later and here we are discussing AIR reinventing itself.
yeah, im kicking my self i havnt got anything to run at the moment. i did well, two gearboxes in my S14A plus a clutch, that rear craddle that fell out in the 32 with 25 running gear on avgas and then 11.4 in that at 122MPH or thereabouts
i think the whole thing of no one going boils down to
I'm not going to pay good money to go to a facility $20 standard meets and $30 national meets so see a flashing light at the end of the track no score boards light towers nothing what are we a 3rd world country
yep spot on madaz even last weekend at heathcote park the timing system buggered up all day and many ppl were pissed that they paid good money for no time slips or a buggered up one the misses did 4 runs in her wrx and the mph didnt record right and that was 2 runs on the left and 2 on the right and thats just not acceptiable ........so air with just a light is even worse for spectator and drivers
Edited by JETURBO
I spoke with Rino about the lack of time boards .... back at the end of the AIR street meet days I had it on good authority that the old timing boards from Calder Park had been transported to AIR and were going to be put up. Then the whole thing turned to shit and shut down. Rino has no idea where the boards are these days (they are no longer at AIR), but he did hint that a good solution was in the works - so fingers crossed he is in the process of getting some!
Ahhhhh the memories ... I was just going through the giant stack of timeslips I still have sitting here in my office window .... my best 60' in the S15 was 1.912 with a run of 12.741 @ 109.01mph - September 2003
and came across these I uploaded years ago under a different username, for your enjoyment
Those were the days!!!!!!!!!!!!!
And thats why the viability of drag racing will suffer here in SA. My 2c
There's no doubt the attendance level of competitors and spectators at AIR of old declined in the latter years. The substandard track surface and inadequate facilities (partial dirt access road, no timing boards, no spectator stands etc.) all contributed to the demise. However, the biggest factor of all; the venue did not have ANDRA sanctioning. Without ANDRA you cannot draw elite level competition drag racing, the kind of regular events that draw crowds, spectators, and sponsorship dollars. I also recall a number influential drag racing identities actively avoiding AIR due to a combination of the owner/s and the lack of ANDRA sanctioning.
All three potential new facilities are actively seeking ANDRA affiliation and sanctioning, which means basic drag racing standards must be met. I have no doubt all three venues are planning digital timing displays for each lane as well as a host of other features that will enhance the experience for competitor and spectator alike.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
