Hi guys,
Names George :D,
I bought myself a 1997 R33 GTR as my 3rd Skyline being on a low budget at the time i sourced out a nice body and interior GTR with the engine in my mind as if its rooted ill enjoy learning on it!
So here it goes im a 2nd year apprentice i work in Thomastown Turbo Engineering and i been learning a hell of alot, so with aspirations to become an awesome mechanic im cutting my teeth on this GTR's engine
alot of people think im crazy and the few think I'm awesome for having a go i think im going to have the best fun of my life!
At the moment the cars sitting outside haven't moved it since i found out it has low comp and slight bottom end knock, now ... since ill be getting the engine out i figured might as-well go all out on it and build it properly
(to what i think is properly anyway lol) i have been saving up alot of doh and purchased most of the stuff i need to get it going again including the following
Cp Pistons 86.5mm
Eagle H-Beam rods (arp bolts)
ACL race series bearings
N1 water pump
Greddy Oil pump
Tomei 1.5mm Head Gasket
Tomei Ex, In, and throttle body gaskets
ARP studs throughout
Tomei Sump baffle kit + mines (type) cam baffles
Tomei Oil restrictor
Things i still need have money for but have not purchased
Haltech platinum pro ecu ( have been told its awesome but still researching )
ATI super damper harmonic with water pump pully.
set of coilovers as mine are rooted
still deciding on wheels but digging some TE37 SL's 18x10.5 +12
Cams getting custom made from camtech
cam gears
Garrett 2860-5 turbos
VRS kit :P
So guys feel free to help me out as im literally building a petrol engine from scratch for the 1st time i work on diesel cars alot and i know its different but the mechanics will be the same im sure.
ill post up some pics and stuff soon of the car and so on :D
Added some pics of the parts and my manuals haha i feel like a kid with a lego kit !
Cheers guys hope this turns out wish me luck :D
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/
  • Replies 45
Posted Images
Good on ya mate, I'm currently doing the same, my first engine build is a all out RB26, not a mechanic but have a strong passion for this, alot of my mates have written me off, and sure it's a very expensive learning curve but why not aye. Mines just having the loom made and should breathe life Monday or Tuesday for the first time, over 3 years of saving and sourcing parts and plenty of research on this site, and a few annoying questions finally coming to fruition, it's like have a baby
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-5996223
id also suggerst that u invest in a larger sump to help with the oil issues.
pm J'z r33 on here, i think he might still have his performance metal craft 9L sump still for sale.
if u get this then u dont need your sump baffle kit
other than that u are on the right track
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-5998051
Thanks for the support fellas, it really helps lol i spent 380 last night on a genuine vrs kit has some doubles like head gasket n common gaskets but has every seal and washer that i need that u cant find ill keep spares prolly sell some that i dont need.
Anyway ill keep updating thanks guys
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-5998077
Ok today was a awesome day... i received my genuine nissan gasket kit ! comes with a tube of genuine nissan gasket cement lol! at least i don't have to worry about various gaskets o'rings and washers now :D
And i purchased a set of 2860r-5 Garrett turbos as-well which will arrive at my work tomorrow morning cant wait :D
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6003476
post-53107-0-85315100-1316248929_thumb.jpgOK guys ive started to pull out the engine all is going ok.. but once i got to the driver side drive shaft i kind of ran into some trouble
i have no clue how this comes out and ive searched high and low even in the manual does not give any info just says remove drive shafts
ive gotten so far as you can see in the pics but i decided ill stop and wait for some info before i stuff something chek out the pics and let me know if im on the right track...
one shows the front shot of the shaft on the diff and the other is a side view of how far i got it out... i dident pull it right out..
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6019728
Okay! with barely any help what so ever lol.. me and 2 mates got it out the drive shaft issue was solved just removed the spider out of the housing... and twisted the engine to clear the chassis
Now the strip down begins! :D
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6021055
Hey guys just a small update on the GTR
I have just started to strip it down a bit took off the turbos which seem ok for a old engine my boss is giving me some cash for them which is sweet!
and my ATI balancer has arrived :D
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6032759
Did some progress this weekend but was held up getting the head off so i can send the block to get done reason was i did not have a harmonic puller so i could not get to the the lower timing case :( ah well
this weekend will be the strip complete and the rebuilding will take place.!post-53107-0-81297800-1317631757_thumb.jpg
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6042902
Head off this weekend and inspection shows me reasons for low comp in cylinder 1, is fair bad pictures are decent but in person when u feel it its deep.
also alot of ware on the lifters :( cams looked like they had small bits of rust on them must have been sitting around alot how sad...
The other cylinders seem as if the engine had been rebuild before the cylinders had that honing look not sure if this is factory but on a 300,000km engine i wouldn't think the marks would have lasted
anywho hope to send block off to machinist ! wish me luck!
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6051193
in the pic above that shows the scratches inside the cylinder...it looks like theres a crack on the cylinder wall
Yeh i had a good look at it man looks intimidating its at the machine shop in the morning so hopefully i hear some news within the next day or so... wish me luck
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6058169
Good luck.
Its awesome that youre giving it a red hot go!
I hope youre machinist is good because your clearances will either make it or break it. Just wondering how you determined the clearances youre using ie piston to bore, ring end gap etc etc? It takes years and years of experimenting with clearances to get a RB to hold together.
Take your time, make sure everything is 110% because at the power level of -5s everything has to be spot on.
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6064432
Good luck.
Hey femno,
all the clearances will be checked and checked again at my work (workshop) i will be assembling the long motor then bringing it home to attach ancillaries, Duggens balancing in reservoir is my machinist ive herd nothing but good things about them and apparently hes that good i don't have to even measure his work lol, but i will any way the cp pistons come with their own rings.. i assume they should be spot on if any abnormalities are found they will be going straight back lol
it is my 1st time building an engine i figure throw myself in the deep end now learn on some good shit im so optimistic that i wont f**k up if anything does go wrong i will be happily pulling her out and redoing it all again untill i get it spot on im planning to open my own business when i get my papers so i gota lot to learn :D
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6067969
So when you check the clearances what are you going to be comparing them with???
For example piston to bore clearances...what are you going to use? The recommended CP figures? Figures from the internet? Your boss?
The ring end gap also depends on the piston to bore clearance.
Assume absolutely nothing and you will have a better chance of the thing holding together.
https://www.sau.com.au/forums/topic/375961-omggtrs-rebirth/#findComment-6067994
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
