Hey guys, i just picked up a bottle of the Nu Finish Cling Spray Shine, after a quick wash (car was only waxed about 2 weeks ago)
and a dry off you just mist it on, wipe over it with a cloth then pretry much instanty wipe again. For only being 14.99 a bottle i was quite happy with the results.
If anyone else has tried it id be interested in feedback/alternative spray quick shines, Thanks :)
https://www.sau.com.au/forums/topic/375975-nu-finish-cling-spray-shine/
  • 1 month later...
I cant say anything about the Nu finish spray, But Iv been using the Meguiars Ultimate quick wax, Its awsome stuff, A little more expensive but if ur just seeing whats out there i would deffnitly suggest giving it ago.
Righto Dunk ill look into it, im almost out of the nu finish so ill give the Meguiars a go next time
+1 for FI :)
but off the shelf products i do like autoglym products, followed by megs/mothers
noone i love waxes that can be applied without drying, i use them on all my other cars.. but only the best for the skyline :P
i believe FI is releasing a spray wax sooner though .. meant to be similar to OCW which is another great spray wax
  • 2 months later...
Nu finish is the devil. I had to paint a good mates bumper for him. He's the most over the top person when it comes to cleaning his cars (i never thought that could be a bad thing). The bar was painted three times because of the amount of silicon that the new finish left behind. Even after prepsol/wax n grease and correct prep work was done. In the end we degreased the living sh#t out of it and it was fine. Third time lucky i spose. Thats just my 2c anyway. If it was me I'd stick with the same as Jonno34 as far as off the shelf stuff goes.
  • 3 weeks later...
From a chemist's perspective, if a person were to apply over time 4 different polishes > 4 different sealants etc, what's to say that the chemical of one might react with another from a different brand name; and through their incompatibility generate some marks or even flaking?
Has this ever happened?
I mean, if one used a process where Auto Glym was used throughout, or another guy was to use Menzerna throughout & a third guy was to use Meguiars throughout: each product would be compatible with another from the same brand. But surely these companies might end up using chemicals that are incompatible with chemicals from a different brand perhaps?
And if there was an incompatibility? What's the likelihood that the last product applied was blamed for some markings when in fact the product underneath it was the chemical 'time bomb'?
Heck I've even come across two skin creams that needed to be applied to the patients skin where cream A had to be applied throughout the day & the other called B shouldn't. So B had to be applied at night after washing.
Thoughts? > Experiences?
^ i used to be worried about that too, so whenever I bought new products I'd buy a whole companys lineup ..
was usually meguiars back then, and id pick products so that it was mostly all "nxt" stuff etc.
since starting to use FI stuff i went to a mostly FI range of products.
but FI does/used to sell alot of products that were not developed themselves, so the whole brand incompatibility might be disproved by that logic .. I use a range of brands now though, FI keep discontinuing products on their online store that have to be replaced with other brands while their still developing their new product pinch.gif so far I haven't had any problems using different brands of waxes, wash solution etc with my FI stuff :)
(ps did the coilovers arrive yet? - it was meant to arrive before xmas apparently ..)
Damn :( I called up and they told me it would arrive at yours by christmas since I sent it off early in the day :(
hope they arrive soon and you're happy with them!
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
