Texi Wrap Up
Hi, where did you manage to get 32mm release bearing carrier, it's really hard to find one in NZ . I have sort of same setup with xtreme twin plate clutch kit. I have 19mm release bearing with 18mm carrier measured back of bearing to where fork sits but it isn't enough ,it hardly touches fingers once fork pushed all the way back, I measured out and find out I'm short of 18mm. Thanks
@PuReOwNaGe There are rules for for sale adverts. You should read them and comply. There is also a proper forum to do so, rather than just in the regional fora. You won't be able to edit this particular thread, but you should start a new one, following the rules and then report this one so it can be deleted. I'm going to report it myself and delete it myself if I don't see these things happen, anyway.
I just post it cuz it clearly shows my problem...way better than i would take to explain that. Yeah i think/hope he make it little bit better. And that RB is good. I got it from running car(even test drive it) so it is not some engine from unknown car from half across planet 🙂
That's an idea, like an exhaust flap. But yeah nah, spent too much money on this shit box.
