Hi Alex,
It's a 1953 XK120 DHC. We are converting it to RHD. I believe ya mate because I too know very well there is alot of fixing. Especially due to the price range my dad buys them at :) They are such a rewarding car though that they are a pleasure to work on. Removing all the paint off the alloy bonnet and doors was just awesome. Removing the siezed door hinges and repairing was an absolute pain but a joy now that it's done. I could go on for hours on the things we have done so far just on one car. What car's did/does your dad have ?
Grew up with Rovers- P6B mainly, went through about 3 or 4 of them, then onto the honda rovers - quintet, 416, 827, and still has a 75. There was a daimler sovereign (like the 420 compact), a Mark1 Jag, nut and bolt (over 20 years...lol) resto on a MG A, MG Magnette was a bit before my memory, and finally he still has the early MGB GT, that his father bought new in England in good original condition.
He has a NA MX5 these days for the topless fun, all the joy of the MGA, without the pain.
+2 for liking the Chaser. Saw a JZX110 in Dandenong late Wednesday. Did like. Would consider buying if I didn't need/want a wagon.
Same; the boot was just too shallow for me; otherwise I'd be hitting some 1JZ action. The late model vvti single turbo 1JZ's are a much nicer thing to play with.
I still don't think the interiors are quite up to the standard of the Nissan though.
not really, i chipped my current car and its more economical and has more power............ :P
Gotta love the VAG cars for that. What chip did you get / who did it for you Iain, & what gains did they advertise for your car?
I bought the missus a A3 Tdi (125kw / 350Nm std) which I'm trying to convince her to let me upgrade the 'economy'. Most I've looked at don't get a lot more power, but some (supposedly) have as much as 77Nm gain - & that's significant considering how little effort it is to get it done.
+1 Iain; What did you end up using, and what is the end result?
Did you do any supporting mods?
Details man, DETAILS!!!
i got a 2nd hand superchips bluefin for $550. they offer a stage 1 (no supporting mods required) which does 54NMs more and 41HP. stage two can offer half again as much, but need fuel pump, dump pipe and intake. took 3 mins to reflash via a hand controller. ive done no other performance mods to the car. only HID conversion ($2.5k for HID pffft) and a fully integrated ipod interface to the satnav system.
leon, your wifes A3 if its more than 3 years old can do a remap via the consult, however all the new diesels (like andys) need to have the ECU removed and perform a bench flash.
i get boost from about 1500rpm and it wheel spins in the dry around 3k into 2nd gear. wet weather, forget about it. however this is a FWD car :( but it handles VERY well for an ass dragger. the sydney people will see it next weekend if they come to the meet
Edited by zei20l
That's a good price Iain. My preference so far is for Bluefin, but pretty pricey here in Aus. I don't know if I can buy it online from UK (running a special there atm) or if they'll insist I get it here.
And yeah, it's more than 3 yrs old so ridiculously easy way to gain some more grunt, umm, I mean better fuel economy, lol.
then you shouldnt have a problem with a reflash!
i got mine from www.vwwatercooled.org.au there is a good FS section there. i think the diesel engines have a good support forum too.
hahah sometimes economy=power. i can consistently get 10L/100km to and from work. highway, 6.5L/100km
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
