Looking For A Stagea In Sa
fat_stag
 Share
hey guys missing my stagea a bit and looking around to buy another.
thought i would ask on here if anyone has one for sale or knows of one for sale in sa that would be interested in a trade for a r32 manual turbo skyline and a ford courier duel cab 1998 on LPG.
bit of a long shot throwing it in here and i know itn sot the for sale section but its more aimed at the people that may be able to help me out.
cheers guys
I have an S1 full fruit, leather, manual, dual sunroof, tein's, whiteline, big brakes, tv, satnav, reverse cam, square hitch towbar, fmic, 34gtr wheels, I would consider parting with for the correct cash....
 Share
    • OK so I just bidded $500 on an R33 GTS4 that no one seems to want. Waiting on a call from the agent to see if I won. 32 GTS4 is for sale. I can't deal with the temptation to mod it.
    • Might be there for work later in the year. Wouldn't mind catching up with you fellas - can't have too many beers, but will consume copious amounts of takoyaki while executing an asian squat on the side of the road while you blokes sort out your hangovers.
    • I know one example is a anecdote not data, but I'm running the same Aeroflow 525 at full voltage through a regular relay, and while I've had other fuel problems including melting the factory fuel hat, the pump itself has been fine for years. Of course, they aren't *that* expensive these days, you could swap in a new one and see if the issue is resolve. I think you had a previous thread about fuel problems, have you been monitoring and logging fuel pressure? Is there anything voltage related (for example does the voltage go up when the pressure goes down)
    • Slap a 460L into the car, send its mum.
    • So last night pulling away from the lights, I lost power for about 1 second. Bit weird, but I kept driving... 5 minutes later the pump completely dies. When I tried to start the car, the pump won't even prime.  I left the car for about an hour, tried to start it and it all appeared fine. Pump primed, car started, got the fuel pressure I should have.... Start driving home, 5 minutes later it dies again. I'm stuck in a shit spot this time going up hill with a car right behind me, so I just let the car continue to turn over while praying to the fuel pump gods. After about 2 minutes of turning the engine over, the fuel pump came back to life and I got home (only about another 5 min away).  So I've been digging around online, it seems like the 525 fuel pumps really don't like to be run at 100% all the time. I've found quite a few examples online of people killing their Walbro 525 pumps within about a year of usage when they are run without PWM.  So, my pump is an Aeroflow 525 (AF49-1057) and I've been running it at 100% without PWM. I'm thinking the Aeroflow 525 didn't like being run at 100% and has burnt itself up.  I really am sick of dealing with fuel pump issues, my current thoughts are -  1. Use a Walbro 450 and run it without PWM. It seems like these pumps hold up pretty well to being run at 100% all the time. I only make about 350kw and can't see me making any more power any time soon so this is probably a fine option.  2. Get a Walbro 525, run it with PWM. I know doing this will annoy me as I feel like with only 350kw, its extra expense that I don't "need" and I'll be thinking the whole time while setting it up that I should have gone with option 1. I know I'll be happy with this option when its setup and running, its only the initial setup frustration and cost as an issue.  3. Get a Walbro BKS1001 brushless pump. This is the fu*k it I'm already going PWM, might as well go full retard. This option just seems better in every way, with the only downside being cost. But I don't know much about this pump so I could be wrong.  Happy to get everyone's thoughts before I go digging around in the fuel tank again.
