I received the quote from Ceva 2day for gtr transport.
VehiclesNISSAN SKYLINEQuote Charges:AUD 3330.65GST:AUD 333.07Total Charges:AUD 3663.72
Unfortunately this is a bit much for me, so will wait for 1 to pop up closer to this side of the country.
Thanks 4 all ur help guys.
Ring some other companies - that's a terrible quote.
I was thinking about this last night, expecting quotes to come in around the $1400 mark, it should be possible to get it back here for less. The flight has to be cheap (jetstar on sale), don't speed with it at ALL (lower speed = better fuel econ so stick to 110kmh and stay constant throttle not on boost off boost), drive each day until you're tired than put the seat back and sleep in the car (not as comfortable as a hotel but saves $80-100 per day and allows you to drive each day until you're tired so you don't rely on motel locations). It's not exactly a fun few days, but I've done similar (2400+ k's one go) and once you have a shower at the end and a good sleep you're fine.
He's right, that quote is nuts. more than a fresh paint job on another gtr I'm guessing.
Steve-o that's a pretty epic trip. How long did it take?
Yeah needed some new CD's for that one. 15 hours there from memory, 3 hours stop waiting for someone else who was late so I had a sleep in the car, then straight back another 15 hours. I slept well after that.
hey guys i transported my 32gtst through ceva from perth to sydney depot to depot cost me $720 and took 6 days to get it. That was in 09 so prices could have gone up. hope that helps
ok, ill take one for the team and voluteer to help drive back.
i once bought a car from adelaide due to price.
flew down from sydney, train out to location suburb, test drive car, drive back.
done this with my dad.
24hr round trip.
awesome to drive all that way, get back, crash for a few hours, wake up and see your new pride and joy sitting in the driveway....
just give me some notice so i can out in for holidays at work :thumbsup:
either way you go, good luck finding a car.
Thank u 4 the offer thats very nice of u, but have decided to just wait for a local 1 to pop up. Got another drive around car now so not in as much of a rush 2 get 1. Thanks again tho.
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
