I AM SELLING OR SWAPPING MY LOVED R32 SKYLINE GTST.HAD SO MUCH PLANS FOR THIS BUT PLANNING TO SAVE FOR A HOUSE.PLEASE NO LOW BALLERS OR STUPID OFFERS.IM NOT IN A RUSH TO GET RID OF THIS CAR BECUASE I LOVE IT.
REGO:FEB 2012
1.ADJUSTABLE CAM GEARS
2.GATES TIMING BELT
3.KOYORAD RADIATOR
4.STANDARD AIRRBOX WITH STAINLESS STEEL INTAKE PIPE AND COLD AIR INTAKE PIPE TO AIRBOX
5.STRUT BAR
6.YELLOW JACKET COILPACKS
7.HKS BOV RELOCATED TO FRONT BAR
8.D1 SPEC CATCH CAN
9.ALL WIRING FOR SUB AND AMP IS THERE JUST NEED A SUB AND AMP
10.T3/T4 TURBO
11.3 INCH TURBO BACK EXHAUST
12.GTR INJECTORS 444CC
13.GTR RESISTOR PACK
14.SERVICED ITH MOTUL OIL AND DRIFT OIL FILTER
15.HID'S
16.LOWERED AND KYB SHOCKS
17.TOMEI PONCAMS
18.DUAL STAGE BOOST CONTROLLER WITH SWICTH BUT SWITCH IS NOT CONNECTED
19.CLARION DVD HEAD UNIT
20.MOMO CORSE STEERING WHEEL
21.AUTO METER BOOST GAUGE
22.NISMO SHORT SHIFTER
23.NISMO GEAR KNOB
24.HAS SCRATCH AS SEEN ON PASSENGER SIDE
25.ROOF NEEDS RESPRAY
26.NISTUNE NEEDS A RE TUNE
27.DASH LIGHTS FLICKER
28.GTR REAR SWAY BAR 24MM THICK
29.FMIC
OTHER PARTS FOR SALE:
1.R34 HIGHFLOWED AND STEEL WHEEL TURBO
2.38MM TURBOSMART EXTERNAL WASTEGATE
3.STANDARD EXHAUST MANIFOLD
4.STANDARD REARSWAY BAR
5.ALLOY REAR SUBFRAME BUSHES BRAND NEW BOUGHT FROM JUST JAP
6.WALBRO 255 FUEL PUMP
7.BRAND NEW SARD FUEL PRESSURE REGULATOR
8.BRAND NEW HPI DUMP PIPE MADE IN JAPAN
THATS ALL I CAN THINK OFF AT THE TOP OF MY HEAD.
PLZ TXT MY PHONE YOUR OFFER AND QUESTIONS THANKS
post-84737-0-55139300-1315816471_thumb.jpgpost-84737-0-18652000-1315816496_thumb.jpgpost-84737-0-68887700-1315816514_thumb.jpgpost-84737-0-75292900-1315816529_thumb.jpgpost-84737-0-87378100-1315816555_thumb.jpgpost-84737-0-61960600-1315816569_thumb.jpgpost-84737-0-61960600-1315816569_thumb.jpgpost-84737-0-20931900-1315816583_thumb.jpgpost-84737-0-76403300-1315816604_thumb.jpgpost-84737-0-32259900-1315816619_thumb.jpg
https://www.sau.com.au/forums/topic/376965-for-sale-or-swap-r32-gtst/
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
