For Sale is my Single turbo setup off my R32 gtr.
Garret T04z .70 / .84 3" v-band. - $1500
Vipec plug-in Ecu, Boost controler included (rb26) - $2000
XsPower Stainless steel T4 Split pulse Manifold (Also Suits T3 Flange) - $500
4 Bolt WasteGate With screamer ( 12 psi spring) - $300
4" Turbo Inlet Pipe can use with stock blow off valves, Comes with 4" K&N filter - $200
Turbo to Intercooler pipe (stainless) - $150
3" V-band Dump Pipe with plumb back for wastegate. - $250
Sard Fpr with turbo smart gauge - $150
Twin entry Fuel rail with (-6 AN) fittings - $150
780cc Vdo Siemens injectors - $500
Trust sump extension and baffel with R33 front diff - $650
All prices are ONO.
Thanks
post-38590-0-12345200-1316053132_thumb.jpgpost-38590-0-03291100-1316053164_thumb.jpgpost-38590-0-82291700-1316053206_thumb.jpgpost-38590-0-01284000-1316053229_thumb.jpgpost-38590-0-63219100-1316053248_thumb.jpgpost-38590-0-70868700-1316054359_thumb.jpgpost-38590-0-61893100-1316054405_thumb.jpgpost-38590-0-89461500-1316054427_thumb.jpgpost-38590-0-39854400-1316054445_thumb.jpgpost-38590-0-54083200-1316054472_thumb.jpgpost-38590-0-25115800-1316054516_thumb.jpgpost-38590-0-65166100-1316054626_thumb.jpgpost-38590-0-51989200-1316054648_thumb.jpgpost-38590-0-40066600-1316054697_thumb.jpgpost-38590-0-17690400-1316054741_thumb.jpgpost-38590-0-59389500-1316054770_thumb.jpgpost-38590-0-49392800-1316054791_thumb.jpgpost-38590-0-91248200-1316054809_thumb.jpgpost-38590-0-18163000-1316054925_thumb.jpgpost-38590-0-24003400-1316054964_thumb.jpgpost-38590-0-26067000-1316054987_thumb.jpgpost-38590-0-96075400-1316055009_thumb.jpgpost-38590-0-03984900-1316055033_thumb.jpgpost-38590-0-93120100-1316055064_thumb.jpgpost-38590-0-78992000-1316055088_thumb.jpg
https://www.sau.com.au/forums/topic/377260-rb26-single-turbo-setup/
  • 3 months later...
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
