  • Replies 61
Might be different in Vic but in NSW (a few years ago now) my mate had his rego cancelled because he did what Alex said, failed 1st inspection at joe bloggs, went elsewhere failed again, went back to the 1st place and passed, 5-6 months later he got a letter saying his rego was cancelled due to a failed inspection at the 2nd place, because different things were wrong/listed with the car compared to the 1st inspection (joe bloggs), So he had to get the car re-inspected.
hope that makes sense...there are losts of 1st place 2nd place in there.
Whether he was just unlucky and someone clued on at the RTA office stumbled across it or they actually go looking for it I don't know, but it can happen.
Does it?
then why did my lenient place, just write "2nd inspection" on the form with the stuff "rectified" when i did the rego transfer for my 32R? is it different for defects?
Depends who you go to, most places i have been to do it that too, its more so you get more time to fix stuff, you have 14 or 28 days if they fill out the proper rwc paperwork, if they just give you a piece of paper and fill the rwc paperwork on your final inspection there is no time limit.
Also beware of getting 2 rwc's where the paper work has been filled out on the first inspection, i know of one person who got a call from vic roads because they wanted to inspect his car assuming that the second one was dodgy.
Yeah, i understand what you mean.
Looks like the OP's experience with the popo hasn't been particularly pleasant.
umm since when are coilovers illegal? Considering that 'coilovers' is just a fancy name for spring and shock absorbers, sounds a lot like hearsay to me unless someone can prove otherwise.
No mention of coilovers in this document, just keep it at the legal height and you will be fine.
http://www.vicroads....8340/0/VSI8.pdf
when they are jap tein that are not adr approved
also any coilover that has a lower adjustable perch such as tein flex
as far as your document doesnt mention coilovers,that doesnt mean anything
No vicroads document mentions you cannot take off your steering wheel and weld a shifter on there in place,i guess that must be ok then lol
My car has been through a couple of road worthies in its time and has never been done for the coilovers.
I guess every workshop is like a box of chocolates you never know what your gonna get inside :D
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
