ROFL Dean..
Your guess is as good as mine..
But I do know, Tillbrooks are working pretty hard to get them finished. I think its almost been a year now that they have not been on the road. Its ironic, i have never seen John race the whole time we've been together, maybe I am bad luck?
Ps. Congratulations Matt... I wanna see your burnouts!
  • Replies 199
Andy, yeah mate the track was much grippier than the Wednesday night, as you'd expect. I still had 1st and 2nd gear w/spin on most of the passes, but 3rd was fine.
As Chops said there was quite a few running, but at least 5 passes would've been had from start to finish.
Congrats on the 11.93 Martin, I'm slowly working my way down there. If you go mid 11's at LS1 Nats then I'm out of the ball park again :)
I'd love to head over and run at Heathcote, Keir vs. Theo would be worth the trip alone, but it's just not practical for me atm :D
Henry mentioned Keir has a few 2nd hand sets of 275/40/17 NT555R's up for sale. I wouldn't mind snapping a set up for the right price! Maybe a 1.8-1.9 would see me into the 11's? If Ben did it then I don't see why I can't. Practice makes perfect.
Yeah Chops, Wayne got me lined-up in the water and then had me stay on it a LOT longer than I would have normally, and it worked :D Pity the Torrie stuffed me 'cause I was on a quick one :(
Yep Matty still on the same tyres I've been using all along! It was in my usual 100% street trim. Full interior, full exhaust and a completely chockers tank of juice.
I used to be a 14sec driver in a 12sec car, now I'm 12sec driver in an 11sec car :D
I had a run vs. a 32 GT-R - he ran 12.1 @ 122+ vs. my 12.6 @ 119+ and had 97mph at 660' vs. my 92mph. He had a clean pass once of the line, so it shows I've got more top end to come. I just need a clean 5k launch. The 32 had just the drivers seat left in the interior and a side pipe exhaust.
Thanks Erica :)
It probably would've been a bloody good and very close match-up btw you and that 32 GT-R Martin. He mentioned his quickest to date was 11.6 @ 125mph. He had a best of 11.8 on Saturday night.
I wonder how much extra grunt and ET/TS improvements I'd see from removing my exhaust and interior trim? Naaa stuff it... then it wouldn't be a "full trim street car".
I was all lined up side by side ready to give Keir a whooping, and the bugger cut the first amber, red lighted, and sucked me into the same. You really have to watch him being the car in the other lane. The acceleration from around 400ft is incredible. I checked his timecard afterwards, 1/2 track mph 122, mine 92. 30mph....GULP.
Holy shit, 30mph! That's a massive difference over a very short length of track.
92mph at 660' hey? My best is 92mph at 1/2 track. What rwkw and terminals are you getting in the Tonner?
Ive got around 295 - 300rwkw depending on the conditions. Have run 115.9 mph, but also have 1650kg + me to push. The biggest problem is the aerodynamic wind brake that the Tonner applies. It cuts the air like a poorly designed brick. Wipes maybe 3 - 4mph off it at that speed.
Yeah, its been the development bed for GenX2. The kit gave it - at this stage - 10mph and 0.8 seconds improvement over the baseline. Not bad for the money. Like I said though we will go faster, maybe around 11.6 ish. Then the GenX2 comes off, the stocker engine out, and the 427 cuber goes in!
If I was looking to upgrade my LS1 powered Holden I'd be very hard pressed to go past the GenX2 kit. It seems like a very well priced package!
427, very nice. Will that see forced induction too?
True.. Can't beat a big cranky V8.
Only thing that puts me off it these days (while i'm at uni) is the damn fuel consumption.
Hence why I sold my VS V8 that I spent shiet loads on modifying. 5ltr isn't a good option to modify. Once you slap a cam in them they tend to be rather gutless below 3500rpm. Powerband is rather narrow etc. It always felt like it needed a gear inbetween the gears I was in to pull out of a corner hard.
And Matt, GenX2 is ADR approved....
I want to make around 700hp (about 440rwkw or so) without forced induction using the LeMans developed Corvette C5R endurance racing components. Nothing like having a big cranky lump of alloy under the bonnet
Now THAT I can't wait to see!
Dont confuse old school V8 tuning with the latest generation stuff. Its a big mistake. Well setup a C5R should be producing around 500Nm, at 2200rpm, on its way to 900Nm by 4500rpm. It should only need two gears.... but a six speed Holinger would be better :D
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
