  • Replies 199
You should try a One Tonner with an ally tray, locked diff, 4000rpm stall and 500hp.......in the wet.....
I had a stock 9" diff in the falcon, and with BFG Radial TAs, I couldnt get around a corner in the wet without getting sideways, except by idling out - made it pretty challenging braking into traffic.
there is no way you would even get me into the passengers seat in that thing in the wet - I dont have a death wish:)
Actually such is the long wheelbase and suspension design of the Holden that its quite forgiving in daily driving situations. Its as tractable in the wet as the Silvia with the drift suspenion that I used to drive around - the same one the D1 Ken Works guy drifted in Melbourne. ie. its not as bad as you might think
I took my "drag" Skyline for a spirited cruise through that hills last night (in full drag trim :D) and it was able to hang with the odd GT-R quite easily. I don't think I can ever go back to non-R compound rubber now :)
R compound rubber is great through the hills, but noisy and a PITA in normal road driving. Its also not the best stuff to use down the strip. Like I have told ya, and always told ya, there are easy 1.8 60 foots in your car with a set of Nittos or BFGs on board.
The drift Silvia at 1100kg, 1.80 60 with 245/50 17 Nittos
The old XR6 T ute at 1800kg, 1.86 60 with 275/40 17 Nittos
XR8 that I ran on the last RPM day, 1.98 60 with the STOCK issue horrible Dunlop 235/40 17s on it
Look at ssgen3 in Sydney with his current model Monaro (stock manual 6 speed box), 1.63 60 on slicks !! That setup would knock a WHOLE second off your ET Matt.
Then look at Keirs cheating four wheel drive thing 1.37 60 on ET Streets!
Where was I Matt? I was stuck behind Pawley :D I wasn't about to be a hero trying to overtake anyone.
I don't find the 540's to be a PITA or noisy Martin. Mind you I'm probably so used to them now that I don't notice.
Yeah I know there's more to be had in the 60ft and ET department, even on the current rubber - once the driver gets his shite together :)
If 275/40/17 Nittos will fit on the rear and I can get a set 2nd hand (for a reasonable price) I'll stick 'em on ASAP. Any idea if Keir has some and how much he'd want for them Martin?
If I got Nittos I run them on the back all the time. Hopefully they can handle the odd corner OK? Obviously they wouldn't be up to 540 standard with soft sidewalls, but a bit of lateral grip would be nice.
Nittos drive really well on the street, you would be surprised how much cornering power you retain, and how quiet/smooth the ride is. Switch back to normal road tyres and you will be surprised just how noisy and PITA the Rs are!
On the other hand a can loan you a set of second hand Avon Turbospeeds off the back of the Bentley, a lovely soft 255/70 15 thing :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
