  • Replies 199
ARGGGHHHHHHHHHHHHHH Steve you bitch! Damn it, I go out for a few hours and look what happens :rofl:
Steve, if you want to do some kind of a swap (with cash adjustment if need be) let me know mate. For your type of driving the 540's would be much better suited. It makes perfect sense to do a swap :rofl: We can chat about it at work tomorrow.
Either way, thanks for teeing it up Martin :P
Hey Matt, how's the single plate clutch holding up to all the abuse?
Have you noticed any slippage in 4th gear yet?
Cheers,
matt
A deal has been struck. Thanks Steve, you're a champ :spank: If all goes according to plan I'll be heading to AIR tomorrow night to see how I go :D
Matt, no prob's so far! Surprisingly the single plate has handled the job without protest. Then again I did manage to get over 20 passes out of the OEM Nissan clutch, some with 250+rwkw onboard.
AIR does have a website, but I can't remember what the address is? Try a search on SAU under 'AIR', as I recall someone posting a link not long back.
I'm gonna give it a good shot Steve! Just noticed GOT BOOST in WA ran 11.67 @ 120mph (1.6 60ft !!!) on 555R's, so even with my shitty driving skills I should go 1.8-1.9
Nice - I'm probably going to go os giken twin plate now. The singles just don't last! :spank:
Yeah - the Supra which ran a 10.9 ran a 1.63 60 ft with jap coilovers (ie stiff)... The nitto's are superb for that! You just have to rip a monster burnout to get heat in the tyres!
Cheers,
matt
That's the plan Joel. To get the Nittos doing their job you have to go for a big burnout. I'm ready to progress to Burnout Basics 102 :spank:
With over 350rwkw I can see why your clutch can't handle it Matt! With decent grip you should be looking at low 11's at least mate!
Yeppo!
All else going to plan (and it never does).. If I can get my 60fters down to a 1.6, I should be able to run a 10! :spank:
Realistically - low 11's would be good though!
PS - How are you on the gearchanges? Are you savage enough that it'll chirp 4th?
Cheers,
matt
That's the plan mate. To get the Nittos doing their job you have to go for a big burnout. I'm ready to progress to Burnout Basics 102 :D
Yeppo!
Cheers,
matt
Hahaha... you got in before I edited my last post mate. Yeah as I said above at the very least you'll go low 11's with BIG mph.
EDIT: Helps if I read ALL the post!
No mate I'm fairly soft with my gear changes. Quick, but not brutal. I never even get 3rd chirping! Unless the track is very slippery and my tyres aren't hot enough, in which case it doesn't just chirp it spins!
So when are you out next to test these nittos? I'll be very interested to see how low your 60fters get!
Cheers,
matt
Yuppo - I'm hoping to crack 125mph next time I go out.
Re: gearchanges - yeah same - I'm too afraid to be hard on the gearchanges as I'm afraid of the car going sideways at 100+ mph... Nitto's should sort that out though!
Cheers,
matt
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
