Good on you Jez for looking after it the way you do. I just know when your older and these cars are no longer as common on our roads that it will be worth some money for it's condition. But Jez, the wheels, get some dish, same colour, just more dish.
Yeah Gary....I know....im working on it at the moment (savings wise I mean :yes: ) Satin black Te37s or deep dish gold and silver two piece rims is what its going to be....fingers and toes crossed !!
Nice sunny day today....so after I took a casual stroll to the shops and bought some green goblin juice...I topped up the coolant and gave her another good clean up. Then I proceeded to search for tutorials of how to take off the rear view mirror...because I could'nt for the life of me find any screws etc. You yank it off I was told...so thats what I did..and hey presto..it works !!
Plastic primer and then first coat......
Finished product to come soon.....(waiting for it to dry)
VERY HAPPY :P
Extremely satisfied and happy with the finished product.....NO SMELL of paint whatsoever...even with the windows up all night. Looks amazing....and brings me one step closer to the "sleek black" front end look that I am after.
Finished product pictures as promised.....
Very hard to get pictures of it clearly with the tint strip....but hope this sufficies
Edited by jez NF
New project: Door trims !!
Started by taking off the door panel.....three screws at the bottom....one screw inside the plastic "phone holder" thing...one screw behind the door opening lever and one screw underneath the "holding on at high speed handle"
Then I wedged the panel loose......carefully disconnected the power window wires.
SUCCESS :woot:
Started painting the various bits and pieces since they were off anyway......
Before...........
After the first base coat.....
Ever wondered what goes on behind closed doors ;)
Ready for renovation...........
Cutting the new leather inserts to size...they are the same material as my seat covers....matching much :whistling:
Stay tuned...progress pics soon....
Hey Hadouken....I guess time will tell hey... :cheers:
BUT..........these are the reasons why I think it will work / is working already !!
1. There is actually a lot more room to "tuck it" into which cannot really be seen with the naked eye...
When you use a flat head screwdriver it works wonders and I actually pushed in quite a bit of the material...a LOT MORE than I thought would
go in. It kind of goes in and under if you know what I mean.
2. It is held in place by the door handle...the door opening lever and the plastic trim bits sit snug over the material.
3. I dont exactly plan to let the neighbourhood cats come and have a free back scratch.
4. ...and my trump card....hahahaaa...I did use drops of super glue in "strategic locations" :whistling:
I think it looks really nice...so even if it does open up...(which I highly doubt it ever will) I will just do it again.
:thanks: Matt..............yeah they are a quick fix with quite amazing results !!
:thanks: Kory.............hahahaaa..I try and keep myself busy and I love working on the car.
Jonno.......Whats next :miner: with the B :ninja: lackization .......ummm....I will finish off the door trims (drivers side) by tmrw / day after.....then next week I plan to get started on my front bumper.....touching up the stone chip marks.
I also need to get started on the brake calipers......and I want to swap the back wheel from one side and put it on the front (the opposite side) just to give me an idea what a "fatter" "deeper dish" and more aggressive wheel looks like..then when I have two rims with decent dish and offset and can look at the car from one side I am hoping this will help influence my decision to get my new rims quicker.
ALSO.............................................she hasnt been on a dyno for a while.....
so CARS GOING IN FOR A POWER RUN (and general check up)........on wednesday to PZP....my current workshop closed down :spank: (the b@#$%ds) so now have to find a new tuner and get comfortable with a new workshop....
Stay tuned
Happy with most things but Tom reckons the AFRs could do with a tweak and there is scope for improvement...so retune next week.....
Meanwhile....I finished off the drivers door this morning....and in the bargain have now completed the door trim project..woohoo !!
Before.....
After......
Thanks to the mad skills of LJ (your awesome man).......
New boots :wub: .........................................................................................................thoughts??
In other news..................cars being retuned tonight.......yay !! :woot:
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
