Well I am open to suggestions etc...this is still a "finding my feet" stage....BUT I dont like the stretched look....I prefer tyres that are nice and chunky....and tyres that run a sidewall right up to the edge of the rim..if you know what I mean....
So I want rims that run flush up to the guards...but do not stick out (must be fairly legal)....and tyres that are nice and chunky and do not rub....so yeah basically biggest rims that would allow for this ^^^^ is what I am after.
NOTHING BEFORE mid July though......birthday boy ;)
I havent clicked on this thread for a long time and my god I am glad I did!
The car looks amazing and is exactly the image I am aiming for with my 33.
But instead I am going matte black :rolleyes:
So it will be getting the re-trim and all that jaz.
Also around the same numbers we are both pulling.
Have you got a dyno graph we can see because that would be great
Thanks Daniel :thumbsup:
This is what the car is running at the moment.......we did pull 352.9 Hp (road) after running more timing etc..but its too dangerous with a stock head gasket and internals....and I dont really want to break anything for the sake of being a dyno queen and a few different digits..the power curve is nice and linear...and I like the way she comes on now...so yeah
Brake caliper painting day.............................
Had to get the subwoofer and carpeting out to take out the jack...
Started with the back left.....(wheel nuts were bloody stubborn on the front - so will have to get a longer breaker bar or some WD40 tmrw)
Took off the wheel
Gave the brakes a good clean with brake and rotor cleaner
Covered and patched up everything
Before pics
Yo man (with a thick Jamaican accent)...
Designer stud covers !!
Patched up and ready
Remembered to rub some vaseline on the NISSAN bit...hope it works
Came up quite good I thought.....
Also before I forget...special thanks to Jonno for coming to help and for bringing tools...............your awesome man :)
It did...but I decided that the factory off white looks too boring...so once I finish all four I am going to hand paint the NISSAN bit on each a bright fluro red. Gloss black caliper and drum with bright red writing...should look nice I daresay.
Happy with and very proud of the right rear....much easier to do and a lot quicker now that I have "experience"........Have to start taking pics with my camera...phone pics are terrible :/ (but you get the idea)
Nice!! Was talking to m.j.h on the weekend about doing mine as he just did them black BUT seeing your pics makes it so much more appealing..... Thanks for sharing! :thumbsup:
:thanks: ....Yeah they look awesome now - cant believe I didn't do this earlier !!
Cannot wait to do the fronts...the back calipers are tiny compared to them so I am expecting the fronts to look a lot sexier... :bunny:
Also cant wait to buy some bright red to do the lettering...hoping it will look something like this (HAHAHAAA)
Spent about 40k (plus/minus) including buying it (14k)...but that is including EVERYTHING...I have an excel sheet where my latest entry for example is a $4.99 paintbrush that I am using to touch up the tiny spots right near the brake pads that I cant get to with the spray can.
Currently working on getting this laminated......
It will go on the inside of the fuel flap thingo under the Jap monster decal...(pics to come)
Also....rain expected for the next few days so the front calipers will be done mid next week....stay tuned :whistling:
While the wheel was off I decided to clean it...............................yep....great idea (not)
Presenting 16 years of brake dust and road grime....................
Spent the best part of half and hour and they look a tad more presentable............still have a looooooooooong way to go :\
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
